clock problems
desai
View user's profile Send private message Send e-mail AIM Address MSN Messenger
clock problems
PostPosted: Fri Apr 07, 2006 12:33 pm     Reply with quote
I have been using an external 20 MHz clock with my pic 16f874.
Now i wanto change the frequency to 4 MHZ and I changed the code as follows
#use delay(clock=4000000) and the pin from clock is going to 13 of the PIC.
It dosent seem to work as when i check with the scope i see about 450 Hz signal (and not MHz)
do i need to change this line of code too?
#fuses HS
PLEASE HELP .
PostPosted: Fri Apr 07, 2006 12:52 pm     Reply with quote
When you say "external clock", I assume you are using the metal "can"
type of oscillator. It looks like this:
http://rocky.digikey.com/WebLib/Abracon/Web%20Photos/ACO%20SERIES.jpg
Is that correct ?
If so, disconnect the 4 MHz oscillator from the PIC and look at
the output pin with your oscilloscope. If the oscillator is correctly
connected to power and ground, you should see a 4 MHz square wave
on the output pin.
If you're using a crystal, then it will look something like this:
http://rocky.digikey.com/WebLib/ECS/Web%20Photos/HC-49US.jpg
desai
clock
PostPosted: Fri Apr 07, 2006 2:12 pm     Reply with quote
yep the shiny metal kinnda clock like the one in the picture with 4 pins.
Sorry i assumed that the clock and x-tal were the same things.
I dont have a 4 MHz clock I just have a 20 MHz clock. But is there a way to divide 20 MHz clock to be used as a 4 MHz clock.
I thought PIC 16F874 had an internal clock of 4 MHz but did not see anything like that on the data sheet anywhere.
PostPosted: Fri Apr 07, 2006 2:28 pm     Reply with quote
You would have to use an external divide-by-5 circuit.
It's easier just to buy a 4 MHz oscillator.
