		| Author | Message |
		| jventerprises
				| Boot Segment Program Write Prot bit 30F5011 |
				|  Posted: Fri Nov 12, 2010 4:54 pm |   |
				| Hi,
 Is there something I am missing about codeGuard and the DSPIC30F5011?
 I want to just unsecure the entire memory range, ie General Segment with no protection.
 My fuses look correct, but my Boot segment protection bit (FBS:0) always comes back as protection set even though I have requested it shouldn't.
 I am running at 5v
 here are my fuses
  	  | Code: |  	  | #include <30F5011.h>
 #device *=16
 #device ICD=TRUE
 #device WRITE_EEPROM=NOINT       // NO write_eeprom calls in ISRs!!
 #FUSES FRC_PLL4                 //Internal Fast RC oscillator with 4X PLL
 #FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
 #FUSES WPSB16                   //Watch Dog Timer PreScalar B 1:16
 #FUSES WPSA512                  //Watch Dog Timer PreScalar A 1:512
 #FUSES PUT64                    //Power On Reset Timer value 64ms
 #FUSES BROWNOUT                 //brownout reset
 #FUSES BORV20                   //Brownout reset at 2.0V
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOWRTB                     //Boot block not write protected
 #FUSES NOBSS                    //No boot segment
 #FUSES NOEBS
 #FUSES NORBS                    //No Boot RAM defined
 #FUSES NOWRTSS                    //Secure segment not write protected
 #FUSES NOSSS                    //No secure segment
 #FUSES NOESS
 #FUSES NORSS                    //No secure segment RAM
 #FUSES NOWRT                      //Program memory not write protected
 #FUSES NOPROTECT
 and the bits from the hex file
 00008301 0000003F 00008030 00003107 00003307 00000007 00004003
 The item in question always comes back as a 00003106 instead of 00003107 which enables the boot segment write protect.
 I have not posted the entire project since it is huge, but I can if needed.
 I must be missing something about codeguard but I can't see what!
 Jon
		| jventerprises
				| tried 4.114 |
				|  Posted: Fri Nov 12, 2010 8:02 pm |   |
				| problem still exists in 4.114 _________________
 Jon
		| FvM
				|  Posted: Sat Nov 13, 2010 6:12 am |   |
				| CCS managed to introduce several faults with 30F5011 configuration fuses. The most important point is to refer to MPLAB to get a second opinion about correct fuse coding. It may be wrong in some cases, but most likely not
 for months or even years. MPLAB reveals, that WRTB/NOWRTB operation has been inversed.
 The second point is, you can avoid the problems easily by specifying no boot sector related fuses at all. You get F80006 = 310F,
 which is decoded by MPLAB as all boot sector features and protection disabled.
 As often told in the CCS forum, you can always set all configuration bits directly by a #ROM statement, geting rid of the
 compilers erroneous beliefs. Ìf you want correct operation of all configuration fuse commands in PCD, file a bug
 report and patiently wait for CCS to fix the issue, or start the IDE device editor tool and fill in the correct fuse codes yourself.
		| jventerprises
				| Now working |
				|  Posted: Sun Nov 14, 2010 8:37 am |   |
				| Thanks for the suggestions, I had discovered the inversion of the WRTB but in order to clear it I had to change my operating voltage from 3.3 to 5.  It was extremely annoying.
 I have followed your suggestion and just set the config bits directly, not relying on the #FUSE directive.
 Currently I have one giant general segment with no protection.  I have tried to enable standard security on that section but the PIC refuses to accept it. No matter what I program I get no protection.  I assumed it was because I only had one segment defined, so I have enabled the boot and secure segments but to no avail.
 Jon
		| FvM
				|  Posted: Sun Nov 14, 2010 8:47 am |   |
				| There are possibly more bugs in the present PCD implementation of 30F5011 fuses. I don't use the chip, so I can't check if certain settings can be programmed. As said, I would check the fuse settings with MPLAB. |  |
