rhfarm
| 18F452 Timer |
Posted: Tue Apr 04, 2006 4:09 pm |
I am trying to program a 40 Khz squarewave output on port B bit 2. I am using the timer interupt and timer1. The problem is that I can not get a frequence higher then around 31 KHz even when setting the 16 bit counter to start counting up from 0XFFE0. There seams to be around 16 us of overhead . I am using a 20 MHz clock and the timer should be incremented ever 200 ns. The code is listed below. Would be thankfull for any feed back.
#include <18f452.h>
#device *=16 adc=10 //icd=true
#use delay (clock=20000000)
#fuses HS,PUT,NOPROTECT,NOBROWNOUT,NOWDT,CCP2B3,NOSTVREN,NOLVP
int8 z=0;
// This interrupt is used to Drive LED at 40 KHz
// is automatically called ever 25us.
#INT_TIMER1
void wave_timer() {
int i;
set_timer1(0xFFF0);
if(z){
output_low(PIN_B2);
z=0;
else {
output_high(PIN_B2);
z=1;
main() {
while(true){
