pfournier
| multiplication...again |
Posted: Fri Mar 31, 2006 9:28 am |
PCWH 3.245
I know I asked about multiplying before and I did look at the previous messages on this subject, but this just plain bothers me.
Here is the code.
#define BIT_RESPONSE_ENTRY_SIZE 9
signed int16 y;
signed int8 x;
x=0;
//y ends up being 1
y=(unsigned)x*(unsigned)BIT_RESPONSE_ENTRY_SIZE;
printf("ux=0x%x, y=0x%x, uBIT_RESPONSE_ENTRY_SIZE=0x%x\n\r",x,y,BIT_RESPONSE_ENTRY_SIZE);
//y still ends up being 1
y=(unsigned int16)x*(unsigned)BIT_RESPONSE_ENTRY_SIZE;
printf("u16x=0x%x, y=0x%x, uBIT_RESPONSE_ENTRY_SIZE=0x%x\n\r",x,y,BIT_RESPONSE_ENTRY_SIZE);
//this works, as I expected it would
y=_mul((unsigned)x,(unsigned)BIT_RESPONSE_ENTRY_SIZE);
printf("x=0x%x, y=0x%x, BIT_RESPONSE_ENTRY_SIZE=0x%x\n\r",x,y,BIT_RESPONSE_ENTRY_SIZE);
x always equals 0 in this example, why can't I get 0 as a result? _________________ -Pete |
Posted: Fri Mar 31, 2006 11:29 am |
| Quote: | | why can't I get 0 as a result? |
What PIC are you using ? I made your code into the following test
program, and compiled it for both the 16F877 and 18F452 with vs. 3.245
and got these results:
ux=0x00, y=0x00, uBIT_RESPONSE_ENTRY_SIZE=0x09
u16x=0x00, y=0x00, uBIT_RESPONSE_ENTRY_SIZE=0x09
x=0x00, y=0x00, BIT_RESPONSE_ENTRY_SIZE=0x09 |
#include <16F877.H>
signed int16 y;
signed int8 x;
x=0;
//y ends up being 1
pfournier
Posted: Fri Mar 31, 2006 12:00 pm |
Sorry about that, I am using the 18LF8622.
That makes for even stranger results. _________________ -Pete |
Posted: Fri Mar 31, 2006 2:02 pm |
I made a test program for the 18F8622 and compiled it with PCH 3.245.
I don't have your hardware so I used MPLAB simulator and used "UART1"
to display the output. It worked OK. Here are the results:
What do you get if you run it in MPLAB simulator ?
(This post gives instructions on using UART1 for output.
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
The comments about flaky behavior don't apply to current
versions of MPLAB.)
#include <18F8622.H>
signed int16 y;
signed int8 x;
x=0;
//y ends up being 1
pfournier
Posted: Fri Mar 31, 2006 2:43 pm |
Sorry, I don't have MPLAB. I'm running on real hardware. _________________ -Pete |
Posted: Fri Mar 31, 2006 3:14 pm |
If you have a high speed internet connection you could download it:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en019469&part=SW007002
I'm using MPLAB vs. 7.20. The latest is vs. 7.31.
Suggestions:
1. If you have a hardware debugger, you could step through the code
while it's running in your hardware, and look at the intermediate values
and determine where it does something incorrectly.
2. You could step through the code in the MPLAB simulator and at the
the same time, step through the code with your hardware debugger
(perhaps in the CCS IDE). Compare the results at each step. Look at
the internal registers window for differences.
3. You could greatly simplify your test program. Strip it down to
a very simple printf statement. Don't use casting qualifiers that
could possibly be misinterpreted by the compiler, such as "unsigned".
Use CCS-specific keywords such as "int8" or "int16", which mean
"unsigned 8-bit integer" and "unsigned 16-bit integer". In other
words, don't leave anything to chance. Lock down everything.
Once you've simplified the program, see if you still get the error. |
