How to store float in EEPROM??
Falgellus
PostPosted: Wed Mar 29, 2006 9:08 am     Reply with quote
If you see the ccs help you can find this:
How do I write variables to EEPROM that are not a byte?
The following is an example of how to read and write a floating point number from/to EEPROM. The same concept may be used for structures, arrays or any other type.
· n is an offset into the eeprom.
· For floats you must increment it by 4.
· For example if the first float is at 0 the second
· one should be at 4 and the third at 8.
WRITE_FLOAT_EXT_EEPROM(long int n, float data) {
int i;
for (i = 0; i < 4; i++)
write_eeprom(i + n, *(&data + i) ) ;
float READ_FLOAT_EXT_EEPROM(long int n) {
int i;
float data;
*(&data + i) = read_eeprom(i + n);
return(data);
I tried it but seems to have problems in this expression:
I tryed doing test for a lot of time but the best I can get is these functions that runs well:
WriteFloatToEEprom( byte Addr, float data )
int32 a;
a = (int32) ( data * (float)100 );
Write_EEPROM ( Addr , (byte) ( a & 0x000000FF ) );
Write_EEPROM ( Addr +1, (byte) (( a & ( 0x0000FF00 ) ) >> 8 ) );
Write_EEPROM ( Addr +2, (byte) (( a & ( 0x00FF0000 ) ) >> 16 ) );
Write_EEPROM ( Addr +3, (byte) (( a & ( 0xFF000000 ) ) >> 24 ) );
float ReadFloatFromEEprom( byte Addr )
float data;
int32 d2;
d2 = (int32) Read_EEPROM ( Addr );
data = (float)d2;
d2 = (int32) Read_EEPROM ( Addr+1 ) ;
data = data + (float)( d2 << 8 );
d2 = (int32) Read_EEPROM ( Addr+2 ) ;
data = data + (float)( d2 << 16 );
d2 = (int32) Read_EEPROM ( Addr+3 ) ;
data = data + (float)( d2 << 24 );
data = (float) (( data / 100.00) + 0.000001 );
return(data);
Have anybody a better way?
THANK YOU VERY MUCH
Paolo
PostPosted: Wed Mar 29, 2006 9:38 am     Reply with quote
You need to change the way the address arithmetic is done. Use:
  int i;
    write_eeprom(i + n, *(((int *)&data) + i) ) ;
The same needs to be done to the read functions.
The problem is that the functions were probably written a _long_ time ago. When CCS was a lot younger, it (incorrectly), assumed that a 'pointer', always addressed a byte, so taking the pointer and adding 'i', moved you forward one byte. Now CCS (correctly) implements pointers, so if you take a pointer to a float, and increment it, it moves forward by four bytes...
The change to the code, 'casts' the float pointer, into an integer pointer (int *), and _then_ performs the arithmetic, resulting in the correct result.
Falgellus
PostPosted: Wed Mar 29, 2006 11:38 am     Reply with quote
Thank you very much Ttelmah, changing as you said all is ok.
Bye
