rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
3.3V PIC18LF4550 and USB |
Posted: Wed Mar 29, 2006 11:09 am |
I'm thinking of using a PIC18LF4550 at 3.3V for a handheld application. Some of the other circuitry runs at 3.3V only and it just makes it easier to have a single power supply on board.
I want to support USB 2.0, which the datasheet tells me I should be able to do, as long as the rest of the microprocessor runs at < 20MHz or so.
Before I go and order all the parts, I thought I'd check if anyone else has done this and if it worked well for you, or if you'd recommend sticking with a 5V supply for the PIC.
Sorry for the rather open-ended question. Thanks in advance.
Rod |
