ICD0161: (CMemory::Verify) Verify failed (MemType = Program,
Chen
PostPosted: Mon Mar 24, 2003 10:20 am     Reply with quote
It is really frustrating.
I have a program for PIC18F8620. Everything programs fine. I simply add one declaration:
int8 temp8;
and the ICD2 will give the error message of
ICD0161: (CMemory::Verify) Verify failed (MemType = Program, Address = 0x7972, Expected Val = 0xFFFF, Val Read = 0xFFFE)
Any idea?
Thanks!
___________________________
Original Post ID: 13008
Chen
More...
PostPosted: Mon Mar 24, 2003 10:33 am     Reply with quote
1) I tried the same board on another PC, and it worked there.
2) Swap the two ICD2 I have, doesn't make any difference
3) Notice extra message after compiling with CCS:
ICD0157: (CICDAPI::ValidateAccessRequest) Access type and mode not allowed for this memory (Mem = Data) (Mode = ICSP) (Type = Read)
ICD0151: (CMediator::Synch) Failed to sync memory (MT = Data) (Dir = 0x0)
4) Once it had trouble, it will continue have trouble for a few time, even removing the line I added
Original Post ID: 13009
Chen
Problem solved...
PostPosted: Mon Mar 24, 2003 2:51 pm     Reply with quote
The problem is in MPLB ICD2: Ground loop in the system
Original Post ID: 13026
Re: ICD0161: (CMemory::Verify) Verify failed (MemType = Prog
PostPosted: Wed Mar 29, 2006 1:37 am     Reply with quote
I'm getting this problem as well
Do you really think it is just the PC???
Where did you get the information on the ground loop??
