RS232 - number of Stop Bits
spesh
PostPosted: Tue Mar 28, 2006 8:05 am     Reply with quote
I need to talk to a device using 9600 baud, 8 data bits, No Parity, 2 stop bits. Is this possible with the PIC and if so, how do I set it up ? I can't see anywhere that specifies the number of stop bits used.
Regards
Alan
mpfj
PostPosted: Tue Mar 28, 2006 8:56 am     Reply with quote
You need to put the PIC into 9 bit serial mode, and always set the 9th bit to a '1' when you send a character.
This will give you ...
<1 x START> <8 x DATA, 1 x STOP> <1 x STOP>
Simple, eh ? Very Happy
spesh
PostPosted: Tue Mar 28, 2006 9:26 am     Reply with quote
I'm unfamiliar with using 9-bit mode. Can I get the compiler to do this automatically or do I have to access the config registers directly ?
Any pointers (excuse the punn) very much appreciated
Cheers
Alan
SherpaDoug
PostPosted: Tue Mar 28, 2006 9:28 am     Reply with quote
BTW, If you are only listening to the device, you can listen with 1 stop bt. It is only when you transmit to it that it needs a little extra delay between bytes so a second stop bit is added.
PostPosted: Tue Mar 28, 2006 9:33 am     Reply with quote
The compiler can do it directly (bits=9). You have a 'choice', of sending 9 bit values to the I/O routines (using int16's), or of accessing the bit in the RS232_ERRORS byte. Older compilers only support the latter. The supplied RS485 driver, uses 9 bit mode, so you can see how it is done in this.
