Has anybody tried to use fuzzytech's C code with CCS compiler ? If so can you kindly tell me the steps to get the changes to the libraries and other things done. I read a previous post on this topic. After trying out the suggestions, I was still getting quite a few errors.
Can anyone post the reqd. changes and if possible a sample code/ main() along with include files..
Thanks a lot
Arvind
Mark
I read that post. I tried those suggestions. It seems that there are still a few changes to be made for producing a code that does'nt give error on compilation. Pieces of code like the following:
#define VOID void
#define BYTE byte
etc are giving an error called duplicate define. What do i do ?
Arvind _________________ All things fuzzy
Mark
