		| Author | Message |
		| pfournier
				| using PUTC on 2 serial ports |
				|  Posted: Wed Mar 22, 2006 8:46 am |   |
				| I have 2 serial ports set up.  Call them S1 and S2.
 I put in the #use rs232(....) statements in with the one for S1 last as that is the one I use for printf statements.  Unfortunately it automatically becomes the default port for PUTS.
 I would like to use PUTS with port S2.  How do I go about that, or can I?
 -Pete
		| Mark
				|  Posted: Wed Mar 22, 2006 8:49 am |   |
				| READ THE MANUAL!  StReAmS!  This comes up all the time.  From the help file:
  	  | Quote: |  	  | Syntax: puts (string).  value = fputs (string, stream)
 Parameters:
 string is a constant string or a character array (null-terminated).  Stream is a stream identifier (a constant byte)
 Returns:
 undefined
 Function:
 Sends each character in the string out the RS232 pin using PUTC().   After the string is sent a RETURN (13) and LINE-FEED (10) are sent.  In general printf() is more useful than puts().
 If fputs() is used then the specified stream is used where puts() defaults to STDOUT (the last USE RS232)
 Availability:
 All devices
 Requires
 #use rs232
 Examples:
 puts( " ----------- " );
 puts( " |   HI    | " );
 Example Files:
 None
 Also See:
 printf(), gets()
		| pfournier
				|  Posted: Wed Mar 22, 2006 9:38 am |   |
				| I've never used streams before.  It is what I wanted, but I never made the connection like that before.  (I didn't find it that obvious.)  I hunted through the forum for somthing similar but I guess my search terms didn't make the right hit.
 Unfortuately, it adds 5.5k to my code, which I cannot afford at this point.  I will have to calculate parity on my own.
 Thanks for pointing it out the connection.
 -Pete
		| mpfj
				|  Posted: Thu Mar 23, 2006 4:45 am |   |
				|  	  | pfournier wrote: |  	  | Unfortuately, it adds 5.5k to my code, which I cannot afford at this point. |
 Which PIC are you using ?  How many hardware serial ports does it have ?
 The additional code may be due to your PIC only having a single "hardware" serial port, with the second serial port being iplemented as a "software" comms port.  This requires extra code to be added.
 I would think that using a second "hardware" (if available) would only add a tiny amount of code (for initialisation, etc), whereas using a "software" comms port requires all the code to bit-bang the data in and out.
 It might be worth checking the listing file to see where / what the extra code is.
		| pfournier
				|  Posted: Thu Mar 23, 2006 7:19 am |   |
				| I'm using the PIC18LF8622.  It has 2 hardware USARTS.  I thought it sounded extereme as well.  If I get time I'll do a comparison, in the mean time it was pretty simple to add parity myself.  I thought maybe "STREAM" handling might have something to do with it. _________________
 -Pete
		| mpfj
				|  Posted: Thu Mar 23, 2006 7:38 am |   |
				| I've just compiled the following ...
  	  | Code: |  	  | #device adc=8
 #FUSES NOWDT                    //No Watch Dog Timer
 #FUSES INTRC                    //Internal RC Osc
 #FUSES NOPROTECT                //Code not protected from reading
 #FUSES NOIESO                   //Internal External Switch Over mode disabled
 #FUSES BORV25                   //Brownout reset at 2.5V
 #FUSES NOPUT                    //No Power Up Timer
 #FUSES NOCPD                    //No EE protection
 #FUSES NOSTVREN                 //Stack full/underflow will not cause reset
 #FUSES NODEBUG                  //No Debug mode for ICD
 #FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
 #FUSES NOWRT                    //Program memory not write protected
 #FUSES NOCPB                    //No Boot Block code protection
 #FUSES NOEBTRB                  //Boot block not protected from table reads
 #FUSES FCMEN                    //Fail-safe clock monitor enabled
 #FUSES LPT1OSC                  //Timer1 configured for low-power operation
 #FUSES MCLR                     //Master Clear pin enabled
 #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
 #FUSES MCU                      //Microcontroller Mode
 #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=S1)
 //#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8,stream=S2)
 setup_psp(PSP_DISABLED);
 setup_spi(FALSE);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 setup_low_volt_detect(FALSE);
 setup_oscillator(False);
 fprintf(S1, "%s", "Hello");
 //fprintf(S2, "%s", "World");
 Without the 2nd comms port, the code compiles to ...
  	  | Code: |  	  | CCS PCH C Compiler, Version 3.243, 32117               23-Mar-06 13:35
 Filename: C:\Documents and Settings\Mark\My Documents\123.lst
 ROM used: 166 bytes (0%)
 Largest free fragment is 65370
 RAM used: 6 (0%) at main() level
 6 (0%) worst case
 Stack:    1 locations
 If I uncomment the 2nd comms port, the code compiles to ...
  	  | Code: |  	  | CCS PCH C Compiler, Version 3.243, 32117               23-Mar-06 13:37
 ROM used: 222 bytes (0%)
 Largest free fragment is 65314
 6 (0%) worst case
 Stack:    1 locations
 So that's only 56 extra bytes !!
		| pfournier
				|  Posted: Thu Mar 23, 2006 7:43 am |   |
				| Hmmmmmm.  Let me give it a quick retry. _________________
 -Pete
		| Ttelmah Guest
				|  Posted: Thu Mar 23, 2006 7:44 am |   |
				| No, Streams are not really 'handled', but are a flag to the compiler, to connect the associated I/O, to the selected code. I'd be triple checking that the #use statement, has the right I/O pins. The only addition, should be a few dozen bytes for the second serial handler. How does the size change, if you leave the same print statements in place, but swap the stream declarations?. Remember that printing itself, does use a lot of code space, especially with the printf/fprintf statement...
		| pfournier
				|  Posted: Thu Mar 23, 2006 8:01 am |   |
				| Here are the differences in my code.  and the differences in size.  I wonder if having the transmit in an interrupt is what is causing the issue.  When I get time I may try it without the interrupt.
 BTW: pins are correct
  	  | Code: |  	  | #use rs232(baud=ARINC_BAUD, xmit=PIN_G1, rcv=PIN_G2, ERRORS, parity=O, bits=8) //#use rs232(stream=ARINC_STREAM, baud=ARINC_BAUD, xmit=PIN_G1, rcv=PIN_G2, ERRORS, parity=O, bits=8)
 #INT_TBE2 //RS232 #2 send data interrupt
 transmitChar_2()
 while( (bit_test(pir3,4)) && (gunSerial_Out_Flag2!=2) )
 //fputc( gcTx_Buffer2[gunTx_Next_Out2], ARINC_STREAM );
 txreg2=(gcTx_Buffer2[gunTx_Next_Out2]);
 gunTx_Next_Out2=(gunTx_Next_Out2+1)%TX_BUFFER_SIZE;
 if(gunTx_Next_In2==gunTx_Next_Out2)
 disable_interrupts(INT_TBE2);
 gunSerial_Out_Flag2=2;
 CCS PCH C Compiler, Version 3.245, 27769               22-Mar-06 15:58
 Filename: V:\CCDA-PS\Software\Main\ccda_ps_model_1.lst
 ROM used: 60240 bytes (92%)
 Largest free fragment is 5292
 RAM used: 2060 (54%) at main() level
 2141 (56%) worst case
 Stack:    8 worst case (6 in main + 2 for interrupts)
  	  | Code: |  	  | //#use rs232(baud=ARINC_BAUD, xmit=PIN_G1, rcv=PIN_G2, ERRORS, parity=O, bits=8) #use rs232(stream=ARINC_STREAM, baud=ARINC_BAUD, xmit=PIN_G1, rcv=PIN_G2, ERRORS, parity=O, bits=8)
 transmitChar_2()
 //txreg2=(gcTx_Buffer2[gunTx_Next_Out2]);
 CCS PCH C Compiler, Version 3.245, 27769               23-Mar-06 08:53
 ROM used: 65482 bytes (100%)
 Largest free fragment is 50
 -Pete
		| mpfj
				|  Posted: Thu Mar 23, 2006 8:26 am |   |
				| I've added an irq handler to my test code and use fputc() in the isr, but it's still a tiny amount of code used !!
 I think you'll have to compare the listing files themselves and work out where the extra code usage is.
		| pfournier
				|  Posted: Thu Mar 23, 2006 9:35 am |   |
				| As you can probably tell my code is HUGE.  I have a lot of waste right now but I need it in there for testing purposes.
 I have started comparing list files.  What I am finding is that code that has nothing to do with the THAT serial port is expanding for no obvious reason.  As a "for instance" I have a printf statement (which uses the other serial port) with 113 instructions that grows to 136 instructions!
 In fact EVERY printf instruction gets larger!!!!!  I have NO idea why.
 So that is why my code grew so large, every prinf statement got expanded for some reason.
 Perhps I'll write a short program (maybe I'll use to one you provided), add some printfs and see what happens.
 -Pete
		| Ttelmah Guest
				|  Posted: Thu Mar 23, 2006 9:54 am |   |
				| I'd suspect you are running into extra page switching. Ufortunately, this is a 'classic' problem. If (for instance), adding just one extra variable, moves a variable that is in common use, into a bank, which is 'different' from the bank being used by other variables in the same part of the program, every data fetch in that part of the program, to/from that variable, changes from being a single word operation, to really involving three words (change bank, get/put byte, change bank back)...
 This is why re-ordering variables, can have a massive effect on code size....
		| Mark
				|  Posted: Thu Mar 23, 2006 9:59 am |   |
				|  	  | pfournier wrote: |  	  | As you can probably tell my code is HUGE.  I have a lot of waste right now but I need it in there for testing purposes.
 Probably because its adding support for streams to each printf.  If you are not using printf's on the 2nd serial stick with your other approach.  You could also use sprintf to put the data into a string and then output that string to the proper port.  This would save you quite a bit of code.  If you are using many printf's, it might be better to write your own sprintf/printf function.  I believe that CCS "inlines" the code so you program can grow quite large.  If you make your own function, this function can be called multiple times thus saving valuable ROM space.  Here's a link http://www.ccsinfo.com/forum/viewtopic.php?t=6703&highlight=sprintf where PCM noted some printf code.  I have written a printf routine for the C18 but it probably wouldn't be much use since it uses variable arguments and pointers to constants (things CCS doesn't support).
 | You cannot post new topics in this forum You cannot reply to topics in this forum
