need help about printing a decimal number
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Mar 21, 2006 4:22 am     Reply with quote
I need help with this kind of printf
I have this result : " 1234 "
I need to printf : " 12.34 "
Anyone can help me with some code to explain this ??
THANK YOU ALL !!
PostPosted: Tue Mar 21, 2006 4:59 am     Reply with quote
I don't know what is gong on. I saw exactly this post 'yesterday', and replied to it. A number of other threads, seem to have disappeared. Hs there been a server crash or something?...
Anyway, the 'answer' depends on what compiler version you have. With the more recent compilers, the %w format will do what you want. On all but the very latest compilers, this is documented in the 'readme.txt' file in the compiler directory, rather than in the help file. So "%4.2w", will print a long integer, with two decimal places shown.
On older compilers, you have the choice of using float (lots of processor time), or printing the quotient, and remainder using two seperate outputs (using 'ldiv' to generate these is the most efficient way, if your compiler supports this).
Calamar
PostPosted: Wed Mar 22, 2006 12:17 pm     Reply with quote
unsigned int16 number = 65123;
unsigned int16 numberInteger = number / 100;
unsgned int numberfraction = number % 100;
printf(lcd_putc,"%lu.%u", numberInteger,numberFaction);
Best Regards
Daniel H. Sagarra
La Plata (Argentina)
