e
strcat pointer question |
Posted: Wed Mar 22, 2006 4:43 pm |
hi, still learning pointers - can someone explain how to use strcat() to append a single character?
Code: | strcat(stringA, stringB[i]); | doesn't work b/c compiler expects pointer, not a single char at index i.
i tried things like
Code: | strcat(stringA, &stringB[i]); | but i still get "Previous identifier must be a pointer" error. setting a pointer variable first:
Code: | char *c;
c = &stringB[i];
strcat(stringA, c); | also doesn't work.
thanks. |
Posted: Wed Mar 22, 2006 4:59 pm |
To append a single character which is extracted from another string,
you can use strncat() as shown below.
The program below displays:
Also, we don't normally use "c" as a variable name for a pointer.
"c" is used for a character variable. A generic temporary pointer
is usually called "ptr".
Code: | #include <16F877.H>
#include <string.h>
char stringA[20] = {"Hello"};
char stringB[27] = {"ABCDEFGHIJKLMNOPQRSTUVWXYZ"};
char *ptr;
int i;
i = 4;
ptr = &stringB[i];
strncat(stringA, ptr, 1);
printf("%s\n\r", stringA);
Posted: Thu Mar 23, 2006 6:28 pm |
thanks for the quick reply. i didn't see strncat in my manual, that is useful. as it turns out, the error i was getting was due to my passing a string parameter incorrectly. but you are right, i also needed str<b>n</b>cat because i wanted only 1 char. i was confused initally because passing a string name works the same as pointer to that string, but doesn't work in functions like strcat.
void displayString(char string) {
printf("%s", string);
//works the same as:
void displayString(char *string_ptr) {
printf("%s", string_ptr);
char s[6];
char text[6] = "hello";
strcpy(s, text);
displayString(s);
but the first routine does not work with strcat because it expects a pointer. i thought the reference 'string' was the equivalent to a pointer to the first char in the string array. which i think it is, so i'm a still bit confused. |
e
Posted: Thu Mar 23, 2006 6:30 pm |
that was me ('e'), forum logged me out. to clarify:
char string2[7] = " there";
strcat(string, string2); // *compiler ERROR for this line*
printf("%s", string); // ...but this works (by itself)!
strcat(string_ptr, string2); // this works
char s[6];
strcpy(s, text);
displayString(s);
