I2C and PORTC general I/O not working...
petersonj
PostPosted: Fri Mar 31, 2006 12:00 pm     Reply with quote
I have been using the EX_SLAVE.C example sucessfully for simple I2C communications on a PIC16F777.
In the main(), while(true){} loop, I tried to use the the other PORTC pins for general I/O and it looks like the I2C communications stopped functioning or the interupt stopped firing... anyway it doesn't work.
All I did was put output_low(PIN_C7) in the while loop, and now the I2C inturupt does not get called (at least thats what it looks like).
I have searced the form but with no luck.
I would like to use the other six pins for I/O.
Thanks,
Jason
Mark
PostPosted: Fri Mar 31, 2006 12:27 pm     Reply with quote
No problem doing that. Post a small test program that demonstrates the problem.
rnielsen
PostPosted: Fri Mar 31, 2006 3:25 pm     Reply with quote
Make sure that both SDA and SCL are configured as inputs. Simply do junk = input_c(); and that should do it.
