Changing Ports on LCD420
__SIMS
PostPosted: Tue Mar 21, 2006 6:57 pm     Reply with quote
I want to modify LCD420.c to use port F instead of port C for the PIC18F8722. Here is the structure in which port B is defined/used:
#byte lcd = 6 // This puts the entire structure
// on to port B (at address 6)
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_b(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_b(LCD_WRITE);
return( (high<<4) | low);
Mark
PostPosted: Tue Mar 21, 2006 11:45 pm     Reply with quote
Hint #1 read this
and now go read the datasheet to find out what portf is on your PIC.
Hint #2
you said move it from b->f. Take a guess at what the above line should read.
