anybody have any idea on how to generate the CRC-XMODEM checksum using CCS C? I'm trying to interface an RFID reader module (TI product) with 18f877a. They'r using CRC-XMODEM algorithm (poly = 0x8408) for their data CRC. I tried to use CRC.C (of CCSC) but the pattern available for generating 16-bit CRC is only 0x1021 (CRC-CCITT). Any idea on how I cud modify the driver to fit my needs or write another driver? Any help will be highly appreciated. Thanx everyone!
hopefully I could get something for CCS C.
-=alDin=-
Mark
Posted: Tue Mar 21, 2006 11:51 pm
Here's a VB routine that you might find useful (I use it for file transfers)
Const CRC_TABLE_SIZE = 256
Public Sub createcrctab()
'Added by ErrHandler parser
On Error GoTo ErrHandler
Dim b As Long
Dim v As Long
Dim i As Long
'this the number of bits per char: don't change it.
Const BITS_PER_CHAR = 8
'number of bits in CRC: don't change it.
Const CRC_BITS = 16
'CCITT polynomial
Const P = &H1021
'CITT reverse polynomial
'Const P = &H8408
'CRC16 polynomial
'Const P = &H8005
'CRC16 reverse polynomial
'Const P = &HA001
For b = 0 To CRC_TABLE_SIZE - 1
v = b * (2 ^ (CRC_BITS - BITS_PER_CHAR))
For i = 1 To 8
If (v And &H8000) Then
v = v And &H7FFF
v = (v * 2) Xor P
Else
v = v * 2
End If
Next i
crctab(b) = v
Next b
Exit Sub
ErrHandler:
Dim myerror As String
myerror = "The following error has occurred:" + vbCr + _
"Error: " + Format$(Err, "0") + vbCr + Error$(Err) + vbCr + _
vbCr + "This error occurred in Public Sub createcrctab()."
MsgBox myerror, vbExclamation, "Error"
Resume Next
