8 BIT INPUT WITH PIC 16F874 AND DISPLAY ON LCD
RAHUL
PostPosted: Sat Mar 18, 2006 9:43 am     Reply with quote
how do i take 8 bit parallel input with pic16f874??
I need to display this input as integer on 2*16 hitachi hd44780 LCD
(I used up port C of pic to connect to LCD.)
here is PIC datacheet:http://ww1.microchip.com/downloads/en/devicedoc/30292c.pdf
Kindly help
PostPosted: Sat Mar 18, 2006 11:52 am     Reply with quote
The program below will read 8 bits of parallel data on Port B,
and display it on the LCD.
#include <16F874.H>
#include <lcd.c>
int8 value;
port_b_pullups(TRUE);
lcd_init();
   value = input_b();
   printf(lcd_putc, "\f%x", value);
RAHUL
ONE probem
PostPosted: Sat Mar 18, 2006 3:50 pm     Reply with quote
The code works fine but it shows hex instead of decimal.It shows 0f,ff,0a etc.I want to display"Grain depth:"follwed by interger value.Pls help.
Mark
PostPosted: Sat Mar 18, 2006 3:56 pm     Reply with quote
Look up printf in your help file. It show the various format specifiers.
RAHUL
urgent
PostPosted: Sat Mar 18, 2006 6:45 pm     Reply with quote
#include <16F874.H>
#include <lcd.c>
int8 value;
lcd_init();
value = input_b();
printf(lcd_putc, "\f%x", value); --
1)HOW DO I ADD MESSAGE BEFORE THIS \f%x?? I ADDED A MESSAGE THE LCD SHOWED IT REPEATEDLY....PLS HELP
2)How do i convert first 7 bits of input to Integer??and use eighth bit as an error bit???
PostPosted: Sat Mar 18, 2006 7:23 pm     Reply with quote
Just add the message after the \f. See example shown in bold below:
value = input_b();
printf(lcd_putc, "\fValue is: %x", value); --
2)How do i convert first 7 bits of input to Integer ?
Do a bitwise AND with 0x7F. Example:
int8 result;
result = value & 0x7F;
Mask down the value by ANDing it with 0x80 to isolate the top bit.
Then use an "if()" statement to do something if the top bit is set.
Example:
if(value & 0x80)
   // do something here if top bit is equal to 1.
RAHUL
The code I tried
PostPosted: Tue Mar 21, 2006 1:11 pm     Reply with quote
\This is what I plan on doing:
0)The LCD should be clear screen then show"Welcome" till it reveives input at D0.(i do not want to display the previous message in PIC memory)
1)I want to START the LCD when the PIC receives a high input(FROM SWITCH) at pin D0.
2)The LCD should display"Measuring...."till it receives 8 bit parallel input.(The problem is the time in which it receives 8 bit input can vary everytime.)
This is the code I have:
While(1)
{lcd_init();
printf(lcd_putc,”WELCOME!!”);
IF (input(pin_D0))
printf(lcd_putc,"Measuring….”);
value = input_b();
if(value!=00000000)//tried 0 too
if(value & 0x80)
{printf(lcd_putc,"ERROR!!");
{result = value & 0x7F;
printf(lcd_putc,"\fGrain Depth:\n");
printf(lcd_putc,"%u",result);
The code doesnot work.Kindly guide me.
Waiting for a reply.
