builder c++ compatible ?
DriverInside
PostPosted: Thu Mar 23, 2006 9:25 am     Reply with quote
Hello does anyone has try to receive values thru rs232 with a builder c++ program from a C pic program?
I want to know if data type are compatible( int, float, ...) from pic c compiler to builder 5 .
thank you, and sorry for my english Embarassed
PostPosted: Thu Mar 23, 2006 9:31 am     Reply with quote
Not tried it, but you will need to use explicit conversions. Int, in the C++, will normally be an int16, and this will need to be the type used in CCS C for comptibility. Floats will probably not be compatible, I'd expect the C++, to use IEEE floats. there has been code posted here in the past, for IEEE to CCS conversion (and vice versa), and a search on IEEE, should find it. If not I can post these routines.
