Determining Pulse Width with 18f84
aldinlapinig
PostPosted: Thu Mar 16, 2006 8:07 pm     Reply with quote
Hi everyone,
I want to determine the Pulse Width of a signal from a modulator to the PIC. Can anybody give me an idea on how I could do it with 18f84? Thank u so much...
kind regards,
-=alDin=- Smile
PICoHolic
PostPosted: Fri Mar 17, 2006 6:37 am     Reply with quote
Do u mean 16F84 ?
Anyway, here's my suggestion:
Connect your signal to the external interrupt of the PIC (RB0).
1st configure the interrupt from Low to high
Once you get an interrupt, clear a timer and start counting and reconfigure your interrupt for high to low.
When you get a second interrupt, your pulse width will be held in your timer. Then reconfigure your interrupt to low to high... and so on...
Good Luck
Humberto
PostPosted: Fri Mar 17, 2006 11:30 am     Reply with quote
The best info regarding this issue you can find it in:
http://ww1.microchip.com/downloads/en/devicedoc/41214a.pdf
Humberto
aldinlapinig
crc_xmodem...
PostPosted: Sat Mar 18, 2006 8:29 pm     Reply with quote
thanx for the immediate response man.. It'll help a lot. I wud like to ask u again. do u have any idea on how to generate the CRC-XMODEM checksum? I'm trying to interface an RFID reader module (TI product) with 18f877a. They'r using CRC-XMODEM algorithm (poly = 0x8408) for their data CRC. I tried to use CRC.C (of CCSC) but the pattern available for generating 16-bit CRC is only 0x1021 (CRC-CCITT). Any idea on how I cud modify the driver to fit my needs or write another driver? Any help will be highly appreciated. Thanx everyone!
-=alDin=-
Humberto
PostPosted: Sun Mar 19, 2006 9:42 am     Reply with quote
This is a complete XMODEM CRC Protocol calculation posted by
J. Winpenny and for C2C compiler:
http://web.ukonline.co.uk/j.winpenny/pic/txrxmod.txt
Humberto
