PIC 16F684 and the A/D setup problems
theproff
PostPosted: Sat Mar 18, 2006 7:18 am     Reply with quote
I have recently purchased the CCS compiler, but am having problems getting the A/D woking, the only result i get from the following setup is 0x3ff. i am using the latest compiler version 3.245
i have tried the examples in the user guide, and on the CCS web site to no avail as these get errors when compiled.
my system
PIC 16F684
AN0 = battery voltage resistor divider max voltage = 1.1volts = 4.5 battery voltage.
AN1 = VREF, using Zetex 1.22voltage reference chip
RC5 = VREF_ENABLE, this applies battery voltage to the VREF chip
my code
#device PIC16F684 ADC=10
setup_adc_ports(sAN0 | VSS_VREF) ;
setup_adc(ADC_CLOCK_INTERNAL) ;
set_adc_channel(sAN0) ;
OUTPUT_HIGH(VREF_EN) ; //enable vcc to vref chip via 1k resistor
delay_ms(2) ; //wait for voltages to stabilise
uiBatteryVoltage = read_adc() ;
voltage on AN0 pin is 0.6 volts (battery)
voltage on AN1 pin is 1.22volts (vref chip)
adc result (uiBatteryVoltage) will always be 0x3ff, should really be half this value...
SFR's are:
TRISA = 0x3f
ADCON0 = 0xc5
ADCON1 = 0x30
ANSEL = 0x01
ADRESL = 0xff
ADRESH = 0x03
i don't think i have missed anything out, any help with this would be appreciated.
thanks
theproff
PostPosted: Sat Mar 18, 2006 9:59 am     Reply with quote
AN1 = VREF, using Zetex 1.22 voltage reference chip
Look in the 16F684 data sheet at this table on page 146 (in Acrobat reader):
TABLE 15-9: PIC16F684 A/D CONVERTER CHARACTERISTICS:
Param           Minimum
No.    Symbol   Value              Notes
A20    Vref     2.2v
A20A   Vref     2.5v   Absolute minimum for 10-bit accuracy
theproff
PostPosted: Sat Mar 18, 2006 5:49 pm     Reply with quote
PCM Programmer
Thanks for opening my eyes, how stupid am I
