LCD.C driver for multiple LCD panels?
lacolo
PostPosted: Thu Mar 16, 2006 7:05 pm     Reply with quote
This is a follow-up topic regarding driving multiple LCD panels (http://www.wrighthobbies.net/datasheets/VK2220.pdf) from one PIC18F452.
I neglected to mention that I'm using the built-in LCD.C driver. The issue seems to be that the enable pin is set high and low at different junctures in different routines in there. So you can't just turn it on or off.
I suppose I will have to customize the LCD.C routines to accept a display# parameter, and then change them all to address the enable pin for that display#.
Has anyone written a version of LCD.C for multiple displays?
Thanks!
//Cynthia
PICoHolic
PostPosted: Fri Mar 17, 2006 6:54 am     Reply with quote
Let me give you a hint:
If you notcied in the LCD.c, they're using a structure mapped to a specific port. This particular structure has 7 significant bits and one unused bit. What you can do is to use this particular bit to enable a second LCD.
Note:
You may connect the LCDs on a bus.
You should be careful when reading the status of the LCDs (one at a time)
Good Luck
