declaration, combining bytes or formating error?
Harry Mueller
PostPosted: Thu Mar 16, 2006 5:49 pm     Reply with quote
I'm reading the data output from an SRF08 in 2 bytes, the high byte first and the low byte second. I'm combining the two bytes and saving the value in an int16 array[17]. When I print the values using "%lu" to format the output I only get the low byte or only printing one byte, I'm not sure which.
Here is my code:
#include <16F877A.H>
#use delay(clock = 20000000)
#use i2c(Master,sda=PIN_C4,scl=PIN_C3)
main()
int i;
int16 range[17];
  i2c_start();                    //initate start condition
  i2c_write(0xE0);                //device address
  i2c_write(0x00);                //register address
  i2c_write(0x50);                //set units to inches
  i2c_stop();
  delay_ms(105);                   //wait for returning ping
  i2c_start();                    //initiate a new start condition
  i2c_write(0x02);                //address of high byte register
  i2c_start();
  i2c_write(0xE1);                //device address but read
  for (i=0;i<17;i++)
  range[i] =i2c_read(1) << 8;         //read first byte and shift left
  if(i<16)
  range[i] += i2c_read(1);           //read second byte and add to 1st
  range[i] += i2c_read(0);
  i2c_stop();
  for (i=0;i<17;i++)
  printf("range in inches = %lu\n\r", range[i]);
Thanks, Harry
PostPosted: Fri Mar 17, 2006 1:36 am     Reply with quote
You should be able to fix it by casting the i2c_read(1) result to a 16-bit
value before doing the left shift. I think the problem is that CCS
can't be depended upon to do automatic type promotions, as is done
by MSVC, etc. Sometimes CCS does them and sometimes they don't.
range[i] =(int16)i2c_read(1) << 8;
if(i<16)
i2c_stop();
for (i=0;i<17;i++)
If you want to be really safe, you could cast the other two i2c_read()
lines to (int16) as well.
In the other thread with the translated driver code, I initially had
a cast to int16 in there, but I decided check the .LST file and see if
it worked without it, and it did, so I took it out of the code that I posted.
But what if your compiler version needs it ? If you want to be really
safe you could change the SRF08 driver code to this:
range[i] = ((int16)i2c_read()) << 8;
range[i] +=  (int16)i2c_read(0);
See if it improves your results.
rnielsen
PostPosted: Fri Mar 17, 2006 10:08 am     Reply with quote
This line will read data from the i2c bus and then shift it eight places which will then be all 0's. This is _then_ stored in range[].
Try reading the data, storing it into range[] and then shifting range[]. Now read the second byte from the i2c bus and store that into the lower half of range[].
Ronald
Harry Mueller
PostPosted: Fri Mar 17, 2006 1:08 pm     Reply with quote
Thanks PCM and Ronald,
I've tried both solutions and they both work!
Regards, Harry
