Comparator question...
KamPutty
PostPosted: Thu Mar 16, 2006 1:13 pm     Reply with quote
Hi all,
I would like to use a comparator on my 16f688. Looking around on the CCS docs, and here on the site, I'm still alittle unsure.
Here is my pnseudo code...
    // comparators
   setup_comparator(A0_A1);
This says "use one comparator", and the +V is connected to A0, and ground (-) to A1.
    setup_vref(VREF_HIGH|15);
Okay, this is where I'm gonna guess. This is where I tell the system my "trip" point in voltages. And the or "|" allows me to adjust the setting by dividing the power by my value.
Am I safe to assume that VREF_HIGH is determined at run time when I apply power and not a coded constent?
Now to get a value back, I can use the interrupt
#INT_COMP
void isr(){...};
What about this variable that is listed in the 16f688 header file
#bit C1OUT = 0x19.6
Could I just check that?
Thanks all!
~Kam (^8*
PostPosted: Thu Mar 16, 2006 4:08 pm     Reply with quote
See my sample program in this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=22955
