		| Author | Message |
		| rahul Guest
				| LCD using PIC16F874 |
				|  Posted: Thu Mar 16, 2006 9:12 am |   |
				| hello, Wireless receiver sends this 8 bit parallel input to PIC16F874 chip and this is to displayed on 2*16 HD44780 LCD display.
 I will be really grateful if someone can help me do the coding for the PIC chip which recieves 8 bit parallel input and displays it on HD44780 LCD(especially main() to receive input and display it on LCD)
 Sincerely,
 Rahul
		| rberek
				|  Posted: Thu Mar 16, 2006 9:24 am |   |
				| There are literally dozens of examples of interfacing  that family of PIC to that Hitachi LCD controller scattered around this forum, as well as example driver code in the CCS directory. |  |
		| sjbaxter
				|  Posted: Thu Mar 16, 2006 9:26 am |   |
				| As a starting point, show us what you have done upto now and then we will look at it and give you some advice. As you may already have seen (by searching this forum) you will not get any help writing code, unless you make some kind of effort first !!
 This is NOT a forum for getting someone else to write code for you, but to assist you in fixing problems or discussing code that you have already started to develop.
 Your request seems like you have an idea what you want but you just want someone else to do all the work !! I'm afraid this is the wong place for such requests.
 Regards,
 Simon.
		| rahul Guest
				| this is what i have done till now |
				|  Posted: Thu Mar 16, 2006 9:57 am |   |
				| #include <16F874.H> #fuses XT,NOPROTECT,NOWDT,NOLVP,PUT
 // LCD Data Management
 struct lcd_pin_map {
 short int enable;
 short int rs;
 short int rw;
 short int unused;
 int data:4;
 }lcd;
 //Variable Declarations
 byte number;
 long int ADC_Num;
 long int value;
 long int count;
 long int sum;
 long int Num_Output;
 float voltage;
 short reset_mode;
 long int five_second;
 // Interrupt Setup for Click-Button Reset
 #INT_EXT
 void ext_isr()
 static short button_pressed=FALSE;
 if(!button_pressed) // if button action and was not pressed
 button_pressed=TRUE; // the button is now down
 reset_mode=TRUE; // activate reset
 ext_int_edge(L_TO_H); // change so interrupts on release
 else // if button action and was pressed
 button_pressed=FALSE; // the button is now up
 reset_mode=FALSE; // reset reset flag
 ext_int_edge(H_TO_L); // change so interrupts on press
 if(!input(PIN_B0)) // keep button action sychronized wth button flag
 delay_ms(100); // debounce button
 #byte lcd = 7 // LCD is connected to port C
 #define lcd_type 2
 #define lcd_line_two 0x40 // LCD RAM address for the second line
 int CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
 STRUCT lcd_pin_map const LCD_WRITE = {0, 0, 0, 0, 0};
 STRUCT lcd_pin_map const LCD_READ = {0, 0, 0, 0, 15};
 int lcd_read_byte()
 int low, high;
 set_tris_c(LCD_READ);
 lcd.rw = 1;
 delay_cycles(1);
 lcd.enable = 1;
 delay_cycles(1);
 high = lcd.data;
 lcd.enable = 0;
 delay_cycles(1);
 lcd.enable = 1;
 delay_us(1);
 low = lcd.data;
 lcd.enable = 0;
 set_tris_c(LCD_WRITE);
 return ((high << 4) | low);
 void lcd_send_nibble(int n)
 lcd.data = n;
 delay_cycles(1);
 lcd.enable = 1;
 delay_us(2);
 lcd.enable = 0;
 void lcd_send_byte(int address, int n)
 lcd.rs = 0;
 while (bit_test(lcd_read_byte(), 7));
 lcd.rs = address;
 delay_cycles(1);
 lcd.rw = 0;
 delay_cycles(1);
 lcd.enable = 0;
 lcd_send_nibble(n >> 4);
 lcd_send_nibble(n & 0xf);
 void lcd_init()
 int i;
 lcd.rs = 0;
 lcd.rw = 0;
 lcd.enable = 0;
 delay_ms(15);
 for (i = 1; i <= 3; ++i)
 lcd_send_nibble(3);
 delay_ms(5);
 lcd_send_nibble(2);
 for (i = 0; i <= 3; ++i)
 lcd_send_byte(0, LCD_INIT_STRING[i]);
 void lcd_gotoxy(int x, int y)
 int address;
 if (y != 1)
 address = lcd_line_two;
 address = 0;
 address += x - 1;
 lcd_send_byte(0, 0x80 | address);
 void lcd_putc(char c)
 switch (c) {
 case '\f':
 lcd_send_byte(0, 1);
 delay_ms(2);
 case '\n':
 lcd_gotoxy(1, 2);
 case '\b':
 lcd_send_byte(0, 0x10);
 default:
 lcd_send_byte(1, c);
 lcd_init();
 printf(lcd_putc, "Hello World");
 HERE ARE MY PIC PINS:
 PIN1:GROUND
 PIN2:5V
 pin3:POTENTIOMETER
 PIN4 TO PIN 16 OF PIC 16F874
 PIN5 TO PIN 17
 PIN6 TO PIN 15
 PIN 11 TO PIN 23
 PIN 12 TO PIN24
 PIN13 TO PIN 25
 PIN 14 TO PIN 26
 MY LCD JUST CONTRASTS IT DOESNOT SHOW ANY MESSAGE
 DATA SHEET FOR PIC: http://ww1.microchip.com/downloads/en/devicedoc/30292c.pdf
 I want to receive 8 bit parallel input and display it.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
