j_girl Guest
| Convert an Array of Characters to Array of hex equivalent |
Posted: Tue Mar 14, 2006 12:12 pm |
I need to convert an array of characters (Ex: char heater_write[6]= {'H','0','O','K','\r','\0'};) to an array that contains the hex equivalent of each character. (Ex: heater_hex = {4,8,3,0,4,F,4,B, etc...}). Does anyone know a simple algorithm to conquer this task?
Thanks! |
treitmey
Posted: Tue Mar 14, 2006 12:17 pm |
It is hex. But 'H','0','O','K','\r','\0' is 0x48,0x30,0x4F,0x4B
that is h zero o k \r \0
Explain what your trying to do. Are you trying to print something? |
mpfj
Posted: Tue Mar 14, 2006 2:01 pm |
I think the OP is trying to convert an ASCII array to a "nibble" array.
Something like this should do the trick ...
char c;
char *src = &heater_write[0];
char *dest = &heater_hex[0];
for (c = *src; c != '\0'; c = *src++) {
*dest++ = c >> 4;
*dest++ = c & 0x0f;
This is just off the top of my head and untested, but it should give you a general idea as to what to do. |
