Starting to read a MMC (using SPI)
Sone_br
PostPosted: Wed Jul 13, 2005 1:59 pm     Reply with quote
Hi eveybody,
I´m using MPLAB 6.61 with CCS-C Compiler 3.150. I´m trying to initialize and to read a MMC Card using PIC18F258. But i m not have any success. :/
My eletrical schematics is like this : http://www.cc5x.de/MMC/
My problem is basic : after i send command [0x40, 0x00, 0x00, 0x00, 0x00, 0x95] the mmc card not response me with the 0x01.
What´s wrong? Can anybody send me an example?
Thanks a lot.
The code i got from web:
// pic   mmc
// RC2   1 (cs)
// RC3   5 (ckl)
// RC4   7 (dataOut)
// RC5   2 (dataIn)
// mmc pin 1,2,5:
//             mmc
//    --- |3,3kohm|--|--|1,8kohm|--- PIC
//     GND
// Testing to Start and Read a MMC
#include <18f258.h>
#use   delay(clock=4000000)
#fuses   XT,NOWDT,NOBROWNOUT,NOOSCSEN,NOPROTECT,NOPUT
#use    rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#use    fast_io(C)
#byte SSPBUF = 0xFC9
#byte SSPCON = 0xFC6
#byte SSPSTAT = 0xFC7
#bit  BF = SSPSTAT.0
#bit SMP = SSPSTAT.7
#bit CKE = SSPSTAT.6
#bit CKP = SSPCON.4
#bit SSPM1 = SSPCON.1
#bit SSPEN = SSPCON.5
#define LOW(var) (var & 0xFF)
#define HIGH(var) (var>>8)
// Prototypes:
int mmc_init();
int mmc_response(unsigned char response);
int mmc_read_block(unsigned long block_number);
char SPI(char d);
   puts("STARTING...\n\r");
   if(MMC_Init())
   puts("MMC ON\n\r");       // MMC Init OK
   if (mmc_read_block(0) == 1)
      printf("MMC not response for reading \r\n");
/************************** MMC Init ************************/
/* Initialises the MMC into SPI mode and sets block size, returns 0 on success */
int mmc_init()
   int i;
   SETUP_SPI(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_4 );
   *0xFC7 |= 0x40;  // set CKE = 1 - clock idle low (for PIC18F258)
   *0xFC6 &= 0xEF; // set CKP = 0 - data valid on rising edge (for PIC18F258)
   SSPEN=1;      // set SSPEN = 1 - Enables serial port and configures SCK,...
               //   ...SDO, SDI and SS as serial port pins(for PIC18F258)
   SMP=0;
   CKE=0;
   CKP=1;
   SSPM1=1;
   OUTPUT_HIGH(PIN_C2);   // set SS = 1 (off)
   for(i=0;i<10;i++)      // initialise the MMC card into SPI mode by sending clks on
      SPI_WRITE(0xFF);
   OUTPUT_LOW(PIN_C2);    // set SS = 0 (on) tells card to go to spi mode when it receives reset
   SPI_WRITE(0x40);   // send reset command
   SPI_WRITE(0x00);   // all the arguments are 0x00 for the reset command
   SPI_WRITE(0x00);
   SPI_WRITE(0x00);
   SPI_WRITE(0x00);
   SPI_WRITE(0x95);   // precalculated checksum as we are still in MMC mode
   puts("Sent go to SPI\n\r");
   if(mmc_response(0x01)==1) return 1; // if = 1 then there was a timeout waiting for 0x01 from the mmc
   puts("Got response from MMC\n\r");
   i = 0;
   while((i < 255) && (mmc_response(0x00)==1)) // must keep sending command if response
   SPI_WRITE(0x41);  // send mmc command one to bring out of idle state
   SPI_WRITE(0x00);  // all the arguments are 0x00 for command one
   SPI_WRITE(0x00);
   SPI_WRITE(0x00);
   SPI_WRITE(0x00);
   SPI_WRITE(0xFF);  // checksum is no longer required but we always send 0xFF
   i++;
   if(i >= 254) return 1;  // if >= 254 then there was a timeout waiting for 0x00 from the mmc
   puts("Got out of idle response from MMC\n\r");
   SPI_WRITE(0xFF); // extra clocks to allow mmc to finish off what it is doing
   SPI_WRITE(0x50); // send mmc command one to bring out of idle state
   SPI_WRITE(0x00);
   SPI_WRITE(0x00);
   SPI_WRITE(0x02); // high block length bits - 512 bytes
   SPI_WRITE(0x00); // low block length bits
   if((mmc_response(0x00))==1) return 1;
   puts("Got set block length response from MMC\n\r");
   return 0;
/************************** MMC Read Block **************************************/
/**** Reads a 512 Byte block from the MMC and outputs each byte to RS232 ****/
   unsigned long i;
   unsigned long varh,varl;
   varl=((block_number&0x003F)<<9);
   varh=((block_number&0xFFC0)>>7);
   SPI_WRITE(0x51); // send mmc read single block command
   SPI_WRITE(HIGH(varh)); // arguments are address
   SPI_WRITE(LOW(varh));
   SPI_WRITE(HIGH(varl));
   SPI_WRITE(0x00);
   if((mmc_response(0x00))==1) return 1; // if mmc_response returns 1 then we failed to get a 0x00 response (affirmative)
   printf("Got response to read block command\n\r");
   if((mmc_response(0xFE))==1) return 1; // wait for data token
   printf("Got data token\n\r");
   for(i=0;i<512;i++)
      putc(SPI_READ(0xFF)); // we should now receive 512 bytes
   SPI_READ(0xFF); // CRC bytes that are not needed
   SPI_READ(0xFF);
   SPI_WRITE(0xFF); // give mmc the clocks it needs to finish off
   printf("\n\rEnd of read block\n\r");
   return 0;
/************************** MMC get response **************************************/
/**** Repeatedly reads the MMC until we get the response we want or timeout *******/
   unsigned long count = 0xFFFF; // 16bit repeat, it may be possible to shrink this to 8 bit but there is not much point
   while(SPI_READ(0xFF) != response && --count > 0);
   if(count==0) return 1; // loop was exited due to timeout
   else return 0; // loop was exited before timeout
PostPosted: Wed Jul 13, 2005 2:04 pm     Reply with quote
Go to the following thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=23183&start=15
It has code from that website, already translated to CCS and it works.
Douglas Kennedy
PostPosted: Thu Jul 14, 2005 9:39 am     Reply with quote
Couple of things I remember from doing this a while back is that you need to activate the chip select pin then get a command 0 (aka reset) to take then immediately follow with a command 1 (aka idle) command
It might help to look at my MMC_init routine in
FAT 16 file system for MMC using SPI mode
( The code is mostly about FAT16 but it has the low level MMC calls like MMC_init set block len etc.)
http://www.ccsinfo.com/forum/viewtopic.php?t=21721
Sone_br
PostPosted: Thu Jul 14, 2005 10:17 am     Reply with quote
PCM programmer,
Great, It works! Very Happy
I just removed the 1k8ohm resistor. i connected mmc direct to the pic, then mmc response me. Any problem doing it?
Tks!
PostPosted: Thu Jul 14, 2005 11:07 am     Reply with quote
On their schematic, http://www.cc5x.de/MMC/ ther PIC runs at +5v
while the MMC runs at +3.3v. So they need to reduce the 5v CMOS
levels coming from the PIC down to the 3.3v CMOS levels used by
the MMC. That's why they have the 1.8K / 3.3K voltage dividers.
If your PIC is running at +3.3v, then you don't need the voltage
dividers. You should remove them in that case.
PostPosted: Thu Jul 14, 2005 11:53 am     Reply with quote
PostPosted: Thu Jul 14, 2005 12:20 pm     Reply with quote
Though, the input levels for the PIC's SDI pin might work in a hobbyist
situation, as discussed in my first post in this thread.
PostPosted: Thu Jul 14, 2005 12:34 pm     Reply with quote
That's what I said, 'it might work'. And it might not....
I just gave a few suggestions for improvement.
PostPosted: Tue Mar 21, 2006 7:12 am     Reply with quote
[quote="ckielstra"]In combination with a PIC18F458 I strongly recommend to make some changes to the schematic as given in [url]http://www.cc5x.de/MMC/ [/url]. This schematic is a mixture of 3.3 and 5V components and it is working outside of the specifications. For example, your PIC18F458 is specified on the RC4 input (SDI) with a minimum high voltage of 0.7VDD, running at 5V that is a minimum of 3,5V. The 3.3V MMC is never going to comply to this.
Another design mistake is the absence of 100kOhm pull-up resistors on all 3 SPI lines. this will cause start-up problems because the MMC is starting up in an open-collector mode.
You might be lucky to get the circuit to work, but why would you? Replacing your PIC18F458 by an PIC18LF458 allows you to reduce the supply voltage for the whole circuit to 3.3V. Then you can get rid of the resistor networks and CS5203A-3 as well, compensating for the higher costs of the LF-version PIC. For 3.3V operation you'll have to replace the MAX232 by a 3.3V compatible version with the extra benefit that the newer drivers are way more power efficient.[/quote]
