Trouble with LCD VK2220
lacolo
PostPosted: Fri Mar 10, 2006 10:31 pm     Reply with quote
I'm using PIC18F452 with LCD VK2220 (http://www.wrighthobbies.net/datasheets/VK2220.pdf
I have looked up most posts on the forum regarding LCDs. Some helpful tips, but I still have had no luck. My code is all compiling, and LED blinking OK, but the LCD panel is just displaying a line of black squares on the first line (it's a 16x2.)
Here's my code:
// LCD text display
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD
// As defined in the following structure the pin connection is as follows:
//     D0  enable
//     D1  rs
//     D2  rw
//     D4  D4
//     D5  D5
//     D6  D6
//     D7  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
//    (could use D3 for backlight?)
#include <18F452.h>
#include <lcd.c>
int var;
   output_high(PIN_A1);
   output_low(PIN_A1);
   output_low(PIN_A1);
   // arbitrary value
   var = 16;
   lcd_init();
//   delay_ms(10);
   lcd_putc("\fReady...\n");
   //printf(lcd_putc,"\fTest Variable: %U\nOkay?", var);
   while (true) {
      output_high(PIN_A0);
      output_low(PIN_A0);
and
////                             LCDD.C                              ////
////                 Driver for common LCD modules      ////
////        (C) Copyright 1996,2003 Custom Computer Services
//// This source code may only be used by licensed users of the CCS
C  ////
//// compiler.  This source code may only be distributed to other
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.        ////
//// Derivative programs created using this software in object code  ////
//// form are not restricted in any way.                             ////
follows:
//     D0  enable
//     D1  rs
//     D2  rw
//     D4  D4
//     D5  D5
//     D6  D6
//     D7  D7
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
struct lcd_pin_map {                 // This structure is overlayed
           BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
           BOOLEAN unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        } lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
   #byte lcd = 0xF81                   // This puts the entire
structure
#else
   #byte lcd = 0xF83                   // This puts the entire
structure
#else
   #byte lcd = 6                  // on to port B (at address 6)
#else
   #byte lcd = 8                 // on to port D (at address 8)
   #define set_tris_lcd(x) set_tris_b(x)
#else
   #define set_tris_lcd(x) set_tris_d(x)
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag
is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
I have double-checked my wiring as well. Any ideas on what may be wrong? Is a one-line of black squares a usual indicator of a particular problem?
Markdem
PostPosted: Fri Mar 10, 2006 10:45 pm     Reply with quote
Hi lacolo, if the black squares are only coming up on the line you are tring to print on, it sounds like the contrast is set to high. Try playing the with contrast pot.
Mark
lacolo
PostPosted: Sat Mar 11, 2006 10:11 am     Reply with quote
I have a potentiometer controlling the contrast, so I can easily adjust it. I tried that, and no luck. Any other ideas?
Thank you,
Cynthia
Charlie U
PostPosted: Sat Mar 11, 2006 12:21 pm     Reply with quote
lacolo,
In general, if the first line of your LCD module is just dark squares, this indicates that the LCD module has not been initialized correctly. If this is your complete program, it appears that you have not defined __PCH__ as required by the driver to work with the 18F452. Add a line at the beginning of the file that contains your main() function: #define __PCH__ This will force the compiler to use the port addresses for the 18F452.
lacolo
PostPosted: Sat Mar 11, 2006 3:50 pm     Reply with quote
Thanks, but that didn't work either. I tried inserting it, received a duplication error, and then realized it is already in the LCD.C code as #if defined(__PCH__)
Any other thoughts?
//Cynthia
PostPosted: Sat Mar 11, 2006 4:03 pm     Reply with quote
No. The 'point' is that the LCD code, tests 'if' it is defined. The poster was suggesting that _you_ define it, which will then force the test in the LCD code to use the PCH defines.
However this should be unnecessary, since using the PCH compiler ought to automatically define this, which is why you then get the 'duplicate definition' error.
Though you say you have checked your wiring, I'd go back and do it again. Look particularly, for something silly, like two of the wires being shorted, either to ueach other, or a 'whisker' to Vss/Vdd (rather than just for a failure in the connections). It is sounding more and more like a hardware error.
lacolo
PostPosted: Sat Mar 11, 2006 5:13 pm     Reply with quote
Well, I just soldered a different LCD Panel (same model, VK2220), to ensure no stray wires, etc, and I'm getting the same results. 1st line of black squares.
Any other thoughts?
//Cynthia
PostPosted: Sun Mar 12, 2006 2:04 am     Reply with quote
Post a list of the connections that you have made between the LCD pins
and the PIC pins.
lacolo
PostPosted: Sun Mar 12, 2006 3:04 pm     Reply with quote
LCD pins
1 --- GND
2 --- +5V
3 --- 10K Potentiometer b/w GND & +5V
4 --- PIC pin 20 (D1)
5 --- PIC pin 21 (D2)
6 --- PIC pin 19 (D0)
7 --- 10K to GND
8 --- 10K to GND
9 --- 10K to GND
10--- 10K to GND
11--- PIC pin 27 (D4)
12--- PIC pin 28 (D5)
13--- PIC pin 29 (D6)
14--- PIC pin 30 (D7)
15--- GND
16--- +5V
PostPosted: Sun Mar 12, 2006 3:46 pm     Reply with quote
Your connections look normal except for the 10K resistors to ground.
The LCD controller has built-in pull-up resistors on the data lines,
so you shouldn't need to put any resistors on DB0-DB3.
See page 54 of the data sheet:
http://www.sparkfun.com/datasheets/LCD/HD44780.pdf
The LCD interface starts out in 8-bit mode upon power-up, and then is
put into 4-bit mode by the CCS driver. See page 46 of the data sheet.
I haven't tested this, but it's possible that by putting pull-down resistors
on pins DB0-DB3, you may be causing a problem.
lacolo
PostPosted: Sun Mar 12, 2006 4:41 pm     Reply with quote
Hi everyone,
Thanks again for all the help - it is finally working! I reworked all of the electronics onto a new breadboard, and that did it.
No idea, really, what was going on, but now, I'm all ready to go!
//Cynthia
