NickLatech Guest
| problem with pic18f2550 code ... might be my configuration |
Posted: Sun Apr 23, 2006 9:20 pm |
I'm having problems with my pic18f2550 code or configuration.
I have a test board setup that I know works for a pic16f876a (I set it up for the pic18f2550 but tried a pic16f876a after found out that they have a similary pin-out). So i'm pretty sure that the board is not the problem. So next i tried making the simplest code possible to blink an led.. I dont get anything. I donno what the problem is
The board has a 20mhz CR, the problem could be in the configuration. I read the oscillator configuration from the datasheet and it seems that the below fuses should work fine.
If anyone sees a problem please let me know because i'm stumped
Nick
| Code: | //test pic18f2550
#include <18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
output_high(pin_b7);
output_high(pin_a1);
output_low(pin_b7);
output_low(pin_a1);
Posted: Mon Apr 24, 2006 11:47 am |
Try a more simple program. This program assumes you have a
20 MHz crystal. If not, change the clock value to the appropriate
frequency. If your crystal is 4 MHz or below, change the HS fuse to XT.
| Code: | #include <18F2550.h>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, NOPBADEN
output_high(PIN_A1);
output_low(PIN_A1);
NickLatech Guest
Posted: Mon Apr 24, 2006 4:27 pm |
looking at your code I found out what my problem was.. i forgot the infinite loop. working at night sometimes is just a waste of time..
thanks a million for the help!
Nick |
