Cheap graphic LCD
Markdem
Cheap graphic LCD
PostPosted: Mon Mar 13, 2006 2:01 am     Reply with quote
I have come across this. How much would i need to change the GLCD driver that comes with PICC to use it??
http://www.futurlec.com/LED/LCD128X64.shtml
Thanks, Mark
mpfj
PostPosted: Mon Mar 13, 2006 5:25 am     Reply with quote
I have used this LCD before (with an 8051 not with a PIC), and hand coded in assembler the routines required.
They wouldn't be much help to you, but most lcd controller chips (in this case the HD61202) support a small set of commands that are needed to drive the lcd.
I would suggest you get the datasheet for this controller and compare the low-level chipset routines (e.g. data read / write, status read / write) with those provided in the GLCD driver.
If you need any more help, I can probably dig out my old 8051 code (although it's about 10 years old !!) and have a quick look at converting the basic routines to C.
ljbeng
PostPosted: Mon Mar 13, 2006 1:19 pm     Reply with quote
I came accross this link:
http://perso.wanadoo.fr/rs-rey/electronic_ressources/Ressources/8051/GraphicLCD/GraphicLCD.htm
Markdem
PostPosted: Tue Mar 14, 2006 4:28 am     Reply with quote
Thanks guys, i have orded the display. at that price i cant lose Smile
Just for the record, i have also found the following page, which may help someone. Look in the downloads section at the bottom of the page. there is some CCS code for this panel.
http://www.techtoys.com.hk/
Thanks, Mark
