Sending +++ to modem
micknfld
PostPosted: Mon Mar 06, 2006 6:43 pm     Reply with quote
I have a PIC connected to a modem. I use the modem to call another computer to transfer data to it. I am able to connect to the other computer and successfully send data to it. However, I am unable to use the +++ command to return to command mode to hang up the line. The following is part of my code:
fprintf(modem,"atdt,8959%c",13);
fprintf(modem,"data");
fprintf(modem,"+");
fprintf(modem,"+");
fprintf(modem,"+");
fprintf(modem,"ath0%c",13);
I saw a posting on this forum that said that you need to put a delay between the +'s. I tried putting a 150ms delay between the +'s and then a 500ms delay before sending the ath0 command. This didn't work. A also just tried fprintf(modem,"+++") but this didn't work either.
The problem is that the modem just takes the +++ and ath0 and sends it to the other computer as data and the modem remains off-hook.
Any suggestions?
Mark
PostPosted: Mon Mar 06, 2006 7:34 pm     Reply with quote
Try sending
fprintf(modem,"+++");
After you send the "+++" you will need to wait for a response from the modem. If you send data then the modem will think that you are trying to send "+++ath0\n" as though it was data. For starters try this:
Once you see that it works, take out the delay and look for a response.
asmallri
Re: Sending +++ to modem
PostPosted: Mon Mar 06, 2006 10:53 pm     Reply with quote
You need 1 second of "silence" before sending the +++ sequence.
Regards, Andrew
King Virus
PostPosted: Wed Mar 08, 2006 2:59 pm     Reply with quote
...or you pull down the CTS Line. In standart configuration the modem should interpret this as ATH !
*** A good forum is a forum where people respect eatch other ! ***
StuartH
PostPosted: Wed Mar 08, 2006 6:44 pm     Reply with quote
DTR actually, for every modem I've come across.
micknfld
PostPosted: Wed Mar 08, 2006 7:15 pm     Reply with quote
I put a delay of 1 second before sending the +++ sequence. That worked. Thanks.
King Virus
PostPosted: Thu Mar 09, 2006 7:18 am     Reply with quote
Right ! Sorry !
