PIC16F88 comparator
JBM
PIC16F88 comparator
PostPosted: Wed Mar 08, 2006 3:03 pm     Reply with quote
I'm trying to use the PIC16F88's internal comparator, but so far, no joy.
Here's my code:
#include <16F88.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
   setup_oscillator(OSC_8MHZ);
   setup_comparator(A0_VR_A1_VR);  // Comparator mode 2
   setup_vref(0xC0 | 9);
   while(1){
      output_bit(PIN_B5,C1OUT);
it should be strikingly similar to the code here, but isn't identical. This is beacuse my version of PCM is about 2 years old (version 3.184), which is likely to be where my problem is.
If that isn't the case, what am I doing wrong? I've got the voltage reference oupoutting fine on A2, but no matter what my voltage on A0 is, C1OUT is always 0.
Any ideas?
-JBM
PostPosted: Wed Mar 08, 2006 3:28 pm     Reply with quote
In your version of the compiler, the wrong address is used
for the CMCON register.
Here is the code for your version:
... setup_comparator(A0_VR_A1_VR);  // Comparator mode 2
0028:  MOVLW  02
0029:  BCF    03.5     // Bank 0
002A:  MOVWF  1F       // Wrong address for CMCON
002B:  BSF    03.5     // Bank 1
002C:  MOVF   05,W     // Read TRISA
002D:  IORLW  03       // Set A0 and A1 as inputs
002E:  MOVWF  05       // Write to TRISA
002F:  MOVLW  06       // Do a short delay
0030:  MOVWF  77
0031:  DECFSZ 77,F
0032:  GOTO   031
0033:  NOP
0034:  BCF    03.5     // Bank 0
0035:  MOVF   1F,W     // Read the wrong register
0036:  BCF    0D.6     // Clear the CMIF bit
Here is the code for PCM vs. 3.245:
// Note:  Bank 1 is already selected.
0027:  MOVLW  02
0028:  MOVWF  1C       // Set CMCON (0x9c) = 0x02
0029:  MOVF   05,W     // Read TRISA
002A:  IORLW  03
002B:  MOVWF  05       // Set A0 and A1 = inputws
002C:  MOVLW  06       // Do a short delay
002D:  MOVWF  77
002E:  DECFSZ 77,F
002F:  GOTO   02E
0030:  NOP
0031:  MOVF   1C,W     // Read CMCON
0032:  BCF    03.5     // Bank 0
0033:  BCF    0D.6     // Clear the CMIF bit
You could fix this by writing to CMCON directly with a line of code.
Define the address with a #byte statement.
JBM
PostPosted: Wed Mar 08, 2006 3:30 pm     Reply with quote
PCM, you never cease to amaze me.
Thanks a million.
-JBM
