zeroing enums and bit variables at startup
SteveK
PostPosted: Tue Mar 07, 2006 10:09 pm     Reply with quote
Hi there,
I am using the watchdog on a 18F452 to cause the software to carry on from where it left off, ie without program initialisations. I am careful to initialise my variables only if it is a genuine powerup or brownout restart cause.
I have some enums, some of which have only two states, and are stored by the compiler as bit variables.
On a watchdog restart, the whole byte (at addres 0x02EE) which contains 8 bit variables is cleared, though I never set or clear any of these flags/enums through the watchdog restart path.
I also don't have these varibles initialised at the declaraion time.
Is this known behaviour? Can it be turned off? (Using PCWH 3.241)
Many thanks for your help,
Steve
PostPosted: Tue Mar 07, 2006 10:33 pm     Reply with quote
According to the .LST file, the following test program does not clear
the 'mode' variable upon reset. I tested this with PCH vs. 3.241
and 3.245.
Are you using the #zero_ram directive ? If so, then 'mode' will be
cleared upon reset.
#include <18F452.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
enum mode {playing=1, recording=2, stopped=3};
char state;
state = playing;
state = recording;
state = stopped;
PostPosted: Wed Mar 08, 2006 3:34 am     Reply with quote
Do you declare the variables as 'static'?.
If so, the compiler will clear them.
This behaviour changed, a long time ago. The manual will tell you that a static variable will be cleared. Remember that if you declare a variable externally to the main code, it will become functionally static anyway, and in this case will not be cleared (this was what was changed - a long time ago, the compiler would treat such 'default static' variables as if they were static, and clear them as well, which was a pain!...).
So, if I declare:
enum test_enum {waiting=0,checking=1,testing=2};
test_enum val;
The compiler wll declare the variable, and not clear it. However if I declare:
static test_enum val;
The compiler will now clear it.
SteveK
PostPosted: Wed Mar 08, 2006 2:10 pm     Reply with quote
Hi guys,
Thanks so much for your responses. PCM programmer, no, I was not using the #zero ram directive.
Ttelmah, you have hit the nail on the head. I have declared the enum as a static within a function, so that it would keep its value between calls to that function.
The cure, of course, is simply to declare the enum as a global in main part of the program.
I will try this now - if I don't post again, assume all is well :-).
Many thanks again,
Steve
