Compiler adding unwanted extra code
Posted: Sun Mar 05, 2006 11:09 am
Shown below I'm writing a byte using the spi_write command. Since there is a timer calling this routine at certain intervals, there is no need to poll the SPI Transmit in progress bit (0x94.0 or bank1-14.0). I need to free to processor for a interrupt critical routine. Can I remove the excess code without using the #use asm directive?
.................... spi_write(RBZ);
0142: MOVF 33,W
0143: MOVWF 13
0144: BSF 03.5 Don't need from here
0145: BTFSC 14.0
0146: GOTO 149
0147: BCF 03.5
0148: GOTO 144 To here
.................... CCPIF=0;
0149: BCF 03.5
014A: BCF 0C.2
