john
spi problems |
Posted: Fri Mar 03, 2006 6:32 am |
hi forum, iam a ew user of the ccs compiler and after 8 years of assemby code thought i would try some c.
My problem is with the library 25640.c a question for anyone, i am having a few problems but will start simple. Is the driver for use on pics not supporting the spi module? i ask this because in the disassembly code it switches the clock lines high and low. The spi module takes care of this internally and you just poll the bf bit for transfer complete after loading the sspbuf, i have a project with this eeprom connected to a 16f777 and it works fine but not when running under this driver. i know what is in a location of the eeprom and for trial purposes just want to read that location to see how this works but it wont work. i will post some code for my other questions later.
thanks john |
Posted: Fri Mar 03, 2006 1:30 pm |
Quote: | Is the driver for use on pics not supporting the spi module? |
That's correct. CCS probably did it that way because a lot of students
use PICs that don't have a SSP module, such as the 16F628.
Quote: |
I have a project with this eeprom connected to a 16f777 and it works
You need to configure the CCS driver to use the same pins that
your board is using. The 25640.C driver uses pins on Port B,
but according to your post, you're using the hardware SPI pins.
Look at the code below. Notice how I've added four #define
statements above the #include for the driver file. These statements
will override the default pins used by the driver. (Look in the
driver file to see the #ifndef statement which allows the override).
Also, note that I've put the chip select on Pin C0. If your
board has it on a different pin, then edit the #define statement
below to use the correct pin.
#include <16F877.H>
// Tell the 25640.C driver to use the following pins
// instead of the default pins on Port B (which are
// listed in the driver file).
#define EEPROM_SELECT PIN_C0 // Chip select for SPI EEPROM
#define EEPROM_CLK PIN_C3 // Pin C3 is SCK on PIC
#define EEPROM_DI PIN_C5 // Pin C5 is SDO on PIC
#define EEPROM_DO PIN_C4 // Pin C4 is SDI on PIC
#include <25640.c>
int8 result;
init_ext_eeprom();
write_ext_eeprom(0, 0x55);
result = read_ext_eeprom(0);
printf("Wrote 0x55, Read %x \n\r", result);
john
25640 spi driver |
Posted: Sat Mar 04, 2006 5:53 am |
Hi pcm programmer, thanks for your reply. I have the code reading and writing to the eeprom now, its fine. although this is ok my next quest is to modify a driver and rename it for the MAX6902 real time clock and be able to use the spi module as i did in my assembly code project. This ic uses the 1 1 spi mode and i wll need to be able to set this in the setup_spi() line. This should in turn reduce the code needed.
Thanks again
john |
ckielstra
