Input () Function Issue.....
sonicdeejay
PostPosted: Thu Mar 02, 2006 9:24 am     Reply with quote
Guys
I has some issue with input() function,
My code is below:
#include <18F2525.h> // Call for PIC18F2525 Driver
//#device ICD=TRUE
#device ADC=10 // Use 10bits ADC
#use delay(clock=16000000) // 16Mhz Crystal is Used
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
#include <MAX517mod.c>
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#include <stdlib.h>
#include <math.h>
//Start main program
      output_high(PIN_C5); // Power On LED
      delay_us(100);
      while ( !input(PIN_A2) );
      // waits for freq ready signal from A2
        output_low(PIN_C5);//LED OFF
       printf("\n\r we got A2 signal ON");
Even though I tied PIN_A2 with 5V.... It won't proceed the later "printf" statment....
Did I miss to declare something?
Do I have to define PORT A as INPUT??(SET_TRISA???)
thx in advance...
sonic
Smile
PostPosted: Thu Mar 02, 2006 9:55 am     Reply with quote
What you post, should basically work. However on some chips/compiler versions, the default state for some peripherals (especially the comparator), may be 'enabled', and so you should try disabling these:
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
SETUP_COMPARATOR(NC_NC_NC_NC);
The compiler auotmatically handles TRIS for you, setting the port as an input, or output when required.
Also add 'NOBROWNOUT' to the fuses, or set the brownout voltage to a required level.
sonicdeejay
PostPosted: Thu Mar 02, 2006 12:38 pm     Reply with quote
I use PIN C0 as input now...and it is working...
I can't afford to close ADC ports(PORT A) as I am uing 2 ADC...
thx again
sonic
Smile
rwyoung
PostPosted: Thu Mar 02, 2006 2:50 pm     Reply with quote
Read carefully the documentation for SETUP_ADC(). You can configure some pins as analog in, some as reference levels and the rest and digital.
As with most CCS functions, you should also check the LST file against the datasheet. They have had a history of subtle errors.
Rob Young
PostPosted: Thu Mar 02, 2006 3:10 pm     Reply with quote
thx again
sonic
Smile
You are trying a _test_ to get things working. This test does not have any ADC's, so you should turn the ports off, especially since you are using portA.
Once you have the test working, then work out how to turn on the ADC pins you want to use. However you will have problems with your code as shown, since if enabled, port A0, is always an ADC pin.
You do understand that the 'input' function, reads the pins as digital inputs, not as analog, and a pin cannot be used for an ADC pin, and for digital I/O at the same time?...
