Input() Function
sonicdeejay
Input() Function
PostPosted: Thu Mar 02, 2006 9:23 am     Reply with quote
Guys
I has some issue with input() function,
My code is below:
#include <18F2525.h> // Call for PIC18F2525 Driver
//#device ICD=TRUE
#device ADC=10 // Use 10bits ADC
#use delay(clock=16000000) // 16Mhz Crystal is Used
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)
#include <MAX517mod.c>
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#include <stdlib.h>
#include <math.h>
//Start main program
   // ADC Port Initialisation
   setup_port_a( AN0_TO_AN3 | VSS_VDD );
   setup_adc( ADC_CLOCK_INTERNAL );
      output_high(PIN_C5); // Power On LED
      delay_us(100);
      while ( !input(PIN_A2) );
      // waits for freq ready signal from A2
        output_low(PIN_C5);//LED OFF
       printf("\n\r we got A2 signal ON");
Even though I tied PIN_A2 with 5V.... It won't proceed the later "printf" statment....
Did I miss something?
Do I have to define PORT A as INPUT??(SET_TRIA???)
thx in advance...
sonic
Smile
