disassembly listing is blank when I do this...
dlc@frii.com
PostPosted: Wed Feb 22, 2006 11:48 am     Reply with quote
While correcting some FUBARs in my ISR code noted by our astute crowd here, I found something interesting. My disassembly window goes blank when I add a couple of assembler instructions. The following code works as expected:
#int_global
void isr(void)
   #asm
      //store current state of processor
      MOVWF save_w
      SWAPF status,W
      MOVWF save_status
      BCF   status,5                              //Set to page 0 for SFR's
      BCF   status,6
   #endasm
However, if I add the save_FSR code below, the disassembly listing goes away, which leaves me feeling uncomfortable:
#int_global
void isr(void)
   #asm
      MOVWF save_w
      SWAPF status,W
      MOVWF save_status
      SWAPF FSR,W
      MOVWF save_FSR
      BCF   status,6
   #endasm
Does any CCS guru out there know what rule I just violated by doing this?
many thanks,
DLC
Dennis Clark dlc@frii.com
http://www.techtoystoday.com
PostPosted: Wed Feb 22, 2006 1:17 pm     Reply with quote
I can't compile your code as posted. It gets errors.
Can you add the missing items, so it can be compiled ?
PostPosted: Wed Feb 22, 2006 7:01 pm     Reply with quote
Sure, you will recognize it I'll bet...
thanks,
DLC
#include <16F628.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,NOLVP,NOCPD,NOBROWNOUT,MCLR
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
#use fast_io(A)
#use fast_io(B)
#define MAXBIT 13         //5 address, 7 control and one junk timing
int rise[MAXBIT];
int rW=0;
int gotOne = 0;
//save_w and save_status are at 7f and 7e which are available in ALL banks
int save_w;
#locate save_w=0x7f
int save_status;
#locate save_status=0x7e
int save_FSR;
#locate save_FSR=0x7d
#byte FSR = 4
#byte status = 3
#byte TMR1L = 0x0E
#byte TMR1H = 0x0F
#byte PIR1 = 0x0C
#byte CCPR1H = 0x16
#int_global
void isr(void)
   #asm
      MOVWF save_w
      SWAPF status,W
      MOVWF save_status
      SWAPF FSR,W
      MOVWF save_FSR
      BCF   status,6
   #endasm
      rise[rW++] = CCPR1H;                        //save the pulse time
      if (rW == MAXBIT)
         rW = 0;
   gotOne = 1;
      TMR1L = 0;
      TMR1H = 0;
      #asm
      // restore processor and return from interrupt
      SWAPF save_FSR,W
      MOVWF FSR
      SWAPF save_status,W
      MOVWF status
      SWAPF save_w,F
      SWAPF save_w,W
      BCF PIR1,2
      #endasm
   int x;
   int n=0;
   set_tris_B(0x03);
   set_tris_A(0x00);
   //Turn off comparator
      setup_ccp1(CCP_CAPTURE_FE);    // Configure CCP1 to capture falling edge detection
      setup_timer_1(T1_INTERNAL);    // Start timer 1
   for (x=0;x<MAXBIT;x++)
      rise[x]=0;
      enable_interrupts(INT_CCP1);   // Setup interrupt on falling edge
   printf("SONY IR decoder\n\r");
         if (n)
            output_low(PIN_A1);
            n=0;
          output_high(PIN_A1);
          n=1;
         if (gotOne)
         gotOne = 0;
               printf("\n\r%u %u counts ",x, rise[x]);
PostPosted: Wed Feb 22, 2006 7:16 pm     Reply with quote
I'm not sure what you mean by 'blank'. Do you mean that you see
nothing at all, or that just the #int_global routine is missing ?
I compiled your program with PCM vs. 3.242 and MPLAB vs. 7.20.
Here is the code viewed from "View / Disassembly Listing" in MPLAB:
28:                #int_global
29:                void isr(void)
30:                {
31:                   #asm
32:    //store current state of processor
33:                      MOVWF save_w
  0004    00FF     MOVWF 0x7f
34:                      SWAPF status,W
  0005    0E03     SWAPF 0x3, W
35:                      MOVWF save_status
  0006    00FE     MOVWF 0x7e
36:                      SWAPF FSR,W
  0007    0E04     SWAPF 0x4, W
37:                      MOVWF save_FSR
  0008    00FD     MOVWF 0x7d
38:                      BCF   status,5       //Set to page 0 for SFR's
  0009    1283     BCF 0x3, 0x5
39:                      BCF   status,6
  000A    1303     BCF 0x3, 0x6
40:                   #endasm
The .LST file also looks OK:
0000            00372 .................... #int_global
0000            00373 .................... void isr(void)
0000            00374 .................... {
0000            00375 ....................    #asm
0000            00376 .....  //store current state of processor
0000            00377 ....................       MOVWF save_w
0004 00FF       00378 MOVWF  7F
0000            00379 ....................       SWAPF status,W
0005 0E03       00380 SWAPF  03,W
0000            00381 ....................       MOVWF save_status
0006 00FE       00382 MOVWF  7E
0000            00383 ....................       SWAPF FSR,W
0007 0E04       00384 SWAPF  04,W
0000            00385 ....................       MOVWF save_FSR
0008 00FD       00386 MOVWF  7D
0000            00387 ....................       BCF   status,5  //Set to page 0 for SFR's
0009 1283       00388 BCF    03.5
0000            00389 ....................       BCF   status,6
000A 1303       00390 BCF    03.6
0000            00391 ....................    #endasm
PostPosted: Thu Feb 23, 2006 10:25 am     Reply with quote
I'm using 3.242 and MPLAB 7.01. When I pull up the view->disassembly listing I have a blank window. If I leave those offending lines out I have the usual disassembly listing. I note that the .lst file is there also.
DLC
PostPosted: Thu Feb 23, 2006 10:55 am     Reply with quote
I recommend that you upgrade to the latest version of MPLAB.
PostPosted: Thu Feb 23, 2006 1:16 pm     Reply with quote
I just upgraded to MPLAB 7.20 (I already have PCM 3.242) and I get the same results as before.
There must be something else that is causing this problem.
DLC
dlc
PostPosted: Mon Feb 27, 2006 1:18 pm     Reply with quote
DLC
When I added other code in the ISR my dissassembly view magically re-appeared. It appears that there is some kind of bug in MPLAB. ;) Regardless, the code compiles and runs properly regardless of the MPLAB oddity.
thanks all,
DLC
