quick math question
Markdem
quick math question
PostPosted: Sat Feb 25, 2006 8:01 pm     Reply with quote
Hi All, i need to the the following sum in C.
CO2 = 3 * KH * 10( 7-pH )
To do this i have tried:
currentph = 7.8;
currentkh = 4;
phsum = 7 - currentph;
currentco2 = 3 * currentkh * pow(10,phsum);
but it will always give back strange numbers, eg number that have nothing in common with what i am doing. Can sombody help??
Thanks, Mark
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Sat Feb 25, 2006 8:30 pm     Reply with quote
I don't see the problem with the code you have posted, but the problem might exist elsewhere.
Please post also:
- Declarations of variables
- Your erroneous results
- Inputs that produce these erroneous results
- type of PIC you are writing for
jecottrell
PostPosted: Sat Feb 25, 2006 8:51 pm     Reply with quote
Try some of these additions to your code to circumvent the possibility of CCS 'features'.
float phsum     = 0.0;
float currentph = 7.8;
float currentkh = 4.0;
phsum = 7.0 - currentph;
printf("currentC02 = %7.2f\n\r", currentco2 );
I can't guarantee my approach is the correct one, but I bet this will probably spark a lot of good posts from the pros on what does and does not work with mixing of data types and the printf problems inherent in some of the later versions of the CCS compiler. So, with that said, your problem is most likely caused by either data types or printf formats, and without a code snippet that clarifies anything having to do with those problems, you probably won't get a very complete answer.
Good luck,
John
Markdem
PostPosted: Sun Feb 26, 2006 2:30 am     Reply with quote
Thanks for the replys guys.
I have now found out that if i do the following, it all works fine
currentco2 = 3 * currentkh * pow(10.0,-1.0);
but as soon as i change it the the following, all i get as a output is a big fat 0
currentco2 = 3 * currentkh * pow(10.0,phsum);
Here is the whole code.
#include <16F88.h>
#FUSES NOWDT, INTRC_IO, NOPUT, NOMCLR, NOBROWNOUT, NOLVP, NODEBUG, NOPROTECT, NOFCMEN, NOIESO, NOWDT
#use rs232(baud=2400,parity=N,bits=8,xmit=PIN_B5,rcv=PIN_B2)
#include<math.h>
#include<ds1820hood.c>
#include<ds1820water.c>
int serialreq, i;
int currentph;
long readadc, currentwatertemp, currenthoodtemp, currentco2i;
float mathtemp, currentkh, currentco2, phsum;
void tempwork()
      currenthoodtemp = onewire_ds1822_read_temp_c_lite_hood();
      currentwatertemp = onewire_ds1822_read_temp_c_lite_water();
void phwork()
//      readadc = Read_ADC();
//      delay_ms(200);
//      mathtemp = (readadc / 21.7659) * 100;
//      currentph = (9900 - mathtemp) / 100;
           currentph = 8;
      currentco2i = currentco2 * 10;
void main ()
   setup_port_a(ALL_ANALOG);                              //setup adc
      set_adc_channel(2);
   enable_interrupts(INT_RDA);
   while (TRUE)
         output_low(pin_b4);
         tempwork();
         phwork();
                        output_high(pin_b4);
         delay_ms(2500);
Thanks very much.
Mark
kender
PostPosted: Sun Feb 26, 2006 2:46 am     Reply with quote
In your complete code I could not find a place where you initialize currentkh variable. Try this:
      currentph = 8.0; // force to float
      currentkh  = 1.0; // or whatever
      currentco2 = 3.0 * currentkh * pow(10.0,phsum);
Also I couldn't find your calls to printf(). Do you stop the execution at the break point to view the variables?
Markdem
PostPosted: Sun Feb 26, 2006 3:19 am     Reply with quote
Hi kender, thanks for you help.
You could not find when i define currentkh because i am no thinking very well today. Embarassed
Lets try again
#include <16F88.h>
#include<math.h>
int serialreq, i;
int currentph;
void tempwork()
void phwork()
//      delay_ms(200);
      phsum = 7.0 - 8.0;
                printf("co2 =%u",currentco2i);
void main ()
      set_adc_channel(2);
   readadc = 607;
   currentph = 8;
        currentkh = 4
   while (TRUE)
         output_low(pin_b4);
         tempwork();
         phwork();
         delay_ms(3000);
Thanks again, Mark
