USB 2.0 clock #fuses
esoesasí
PostPosted: Thu Feb 23, 2006 10:08 am     Reply with quote
hello, I'm using the pic 18f4550 and I want to communicate with the USB 2.0 full speed. My problem is with the clock that I must put. For example...if I put a clock of 48Mhz, how I define the #fuses(HSPLL, PLL?, CLKDIV?) or... for example, if I put a 12MHz clock, can I work full speed if I make a right configuration of the fuses?in that case, which fuses should I put? thanx anyway..
Milhojas
Mmmm
PostPosted: Thu Feb 23, 2006 1:06 pm     Reply with quote
Suena a argentino. O no ?
No estoy en casa. Cuando llego lo busco y te lo paso.
