verification of typemod and fram
treitmey
PostPosted: Fri Feb 24, 2006 3:10 pm     Reply with quote
Could someone with fram on there system check this. It seems when I use typemod and local (to main) vars the system works. When I change the to globals, the last entry of the list presents an incorrect value
#include <18F452.H>
#case
#use delay(clock=40000000)
#fuses h4,nowdt,noprotect,nolvp
#use rs232(baud=19200,xmit=PIN_C0,invert,stream=DEBUG,disable_ints) // stderr(same as debug)
#zero_ram
int8 ERRORS;
#define FRAM_CHIPS 4
//#include "FM24C256.C"
#include <74595.C>
//----------prototypes--------
void init_fram();
multi_read_fram(int32 address,int8 *data,int8 size);
multi_write_fram(int32 address,int8 *data,int8 size);
typemod <,multi_read_fram, multi_write_fram,0,131071> fram;
//place int8 fram here for global variable
//======================= MAIN ============================//
  int8 fram f_1,fram f_2,fram f_3,fram f_4,fram f_5;
  int16 cnt;
  setup_adc_ports(NO_ANALOGS);
  set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);set_tris_e(0);
  output_low(PIN_C5);//tx enable
  output_high(PIN_C6);
  fprintf(DEBUG,"Start!\n\r");
  init_fram();
  f_1=1;
  f_2=2;
  f_3=3;
  f_4=4;
  f_5=5;
  for(cnt=0;cnt<12;cnt++);
  fprintf(DEBUG,"%u %u %u %u %u\n\r",f_1,f_2,f_3,f_4,f_5);
  fprintf(DEBUG,"DONE !\n\r");
#ifndef FRAM_SDA
#define FRAM_SDA  PIN_C4
#define FRAM_SCL  PIN_C3
#endif
#use I2C(MASTER,SDA=FRAM_SDA,SCL=FRAM_SCL,FORCE_HW,FAST=1000000,RESTART_WDT)
#define FRAM_ADDRESS int32
#define FRAM_SIZE    32768
#ifndef FRAM_CHIPS
#define FRAM_CHIPS   1
#endif
#define FRAM_MAX_ADDRESS (FRAM_SIZE*FRAM_CHIPS)-1 //4 chips 0,1,2,3
#define hi(x)  (*(&x+1))  //data held at addr of x + 1
#define lo(x)  (*(&x))    //data held at addr of x
//======================init_fram===========================//
void init_fram(){
  output_float(FRAM_SCL);
  output_float(FRAM_SDA);
//======================multi_read_fram===========================//
//start addr 0,32768,65536,98304,131072,163840,196608,229376
multi_read_fram(int32 address,int8 *data,int8 size){
  int8 start_size;
  //fprintf(DEBUG,"-mr-");
  start_size=size;
  for(;size;data++,size--,address++)
    if(address>FRAM_MAX_ADDRESS){
      bit_set(ERRORS,4);
      //fprintf(DEBUG,"ERROR address too big!\n\r%lu\n\r",address);
    if(address%FRAM_SIZE==0 || size==start_size){
      //fprintf(DEBUG,"sending slave address=%lu\n\r",address);
      i2c_start();
      i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
      i2c_write(hi(address));
      i2c_write(lo(address));
      i2c_start();
      i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
    if((address+1)%FRAM_SIZE && size!=1)
      *data=i2c_read(1);//The ack will put next data on bus
      //fprintf(DEBUG,"read with ack %lu=%u\n\r",address,*data);
      *data=i2c_read(0);//No ack on last read of chip
      //fprintf(DEBUG,"read without ack %lu=%u\n\r",address,*data);
      //fprintf(DEBUG,"I2c stop\n\r");
      i2c_stop();
  //fprintf(DEBUG,"-mr- done!\n\r");
  //return(TRUE);
//======================multi_write_fram===========================//
  int8 start_size;
  start_size=size;
  //fprintf(DEBUG,"-mw- %lu %lu\n\r",address,size);
  for(;size;data++,size--,address++){
      bit_set(ERRORS,4);
      i2c_stop();
      //fprintf(DEBUG,"I2c start\n\r");
      i2c_start();
    i2c_write(*data);
    //fprintf(DEBUG,"wrote %u\n\r",*data);
  i2c_stop();
  //fprintf(DEBUG,"dmw\n\r");
  //return(TRUE);
