I have a large program code for PIC16F946. Until the code size reaches 25% of program memory everything is ok, but after this limit (Memory usage: ROM=25% RAM=17% - 18%) any more code lines I add crushes the whole code and the program gets locked, doesn't respond any inputs. The lines I added can't do this, there is a wrong CCS Compiler and PIC16F946. Any code can do this, even trying to clear an output like this:
#bit park = 0x7.7
park = 0;
I think compiler can't address its memory correctly. Do you have any idea about this problem? Does CCS Compiler really support PIC16F946?
I'm using:
IDE version 3.243
PCB version 3.243
PCM version 3.243
PCH version 3.243
MPLAB IDE v.7.30
Microchip ICD 2 programmer
treitmey
Posted: Thu Feb 23, 2006 10:52 am
Do a search in the forum (option up above by the CCS)
for #device *=16
This might be your problem
