ljbeng
| Tracing Interrupt Timing |
Posted: Tue Feb 21, 2006 3:26 pm |
I have 3 interrupts in my program. I reduced the program to what you see just to check on the timing. I used a USB Logic Analyzer to get the wave forms below. H11AA1 is an AC input. FORCE forces the AC off. INT is the interrupt on pin_b0 (H11AA1) and RTCC and TIMER1 are toggle outputs every interrupt of RTCC and TIMER1.
There is some latency on INT line after H11AA1 line goes high, but I think there is a big difference in where the Logic Analyzer sees a 1 and where the processor sees a low to high. What bugs me is when I force the AC off and the H11AA1 goes high for a few ms, INT keeps interrupting.
RTCC (Yellow) should be interrupting every 250us yet I only see a change every 6-10ms.
TIMER1 is right on with 25ms interrupts.
| Code: | #include <18F4620.h>
#device ICD=TRUE
#device adc=10
#zero_ram
#use delay(clock=4096000,restart_wdt)
#FUSES WDT //Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#define timerst 39936
#int_RTCC
RTCC_isr()
output_toggle(pin_a2);
#int_EXT
EXT_isr(){
output_toggle(pin_e1);
#int_TIMER1
TIMER1_isr()
set_timer1(get_timer1() + timerst); // .025s overflows with 4.096MHz crystal
output_toggle(pin_a1);
void main(){
int a,b;
set_tris_a(0b11111001);
set_tris_b(0b00000001);
set_tris_c(0b10110000);
set_tris_d(0b00000000);
set_tris_e(0b00000001);
setup_vref(FALSE);
setup_adc_ports(AN0|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_1);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DISABLED,3,1);
setup_timer_3(T3_DISABLED);
EXT_INT_EDGE(L_TO_H);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RTCC);
while (1){
a = 1;
b = 2;
Posted: Tue Feb 21, 2006 3:43 pm |
You are setting the tris registers, but have not selected fast_io. as such the compiler will be overriding these settings.
The unit is behaving as if there is an interconnection to the output being driven by the RTCC, and the INT input. I'd be checking for 'silly' things (like one of the Vdd connections not being made, which can lead to very odd behaviour from the chip), or supply noise being generated by the output line, or a direct interconnection somewhere...
ljbeng
Posted: Tue Feb 21, 2006 4:00 pm |
| Sorry, some of the problem was traces on the board not making it to the connector where the leads were connected. I put the leads right on the processor and got expected waveforms. |
