ipodwaterproof
18f6722.h |
Posted: Thu Feb 16, 2006 1:59 pm |
where can I get 18f6722.h, I used to work with 6720,
thank you for your help,
Tony |
Posted: Thu Feb 16, 2006 3:11 pm |
This is answered every few weeks.
Even if you could get a copy of this file, it _won't_ add support to your compiler for the chip. These files are simple (you could type them in yourself, or modify one from a similar chip), but the actual processor support requires the right compiler, the associated .dat file, and the .h file. You get these as a combination, by buying a newer compiler.
ipodwaterproof
Thank you, |
Posted: Fri Feb 17, 2006 10:42 am |
Hi buddy,
Thank you for your reply, I will ask compiler for help,
Best Regards, |
