I was wondering if there is any way to define a data type of 10 bits or one of 24 bits. I am getting problems with RAM space and the possibility to define this "exotic" data types could solve some of my problems.
Thanks in advance.
Best Regards,
Eduardo
rwyoung
Posted: Tue Feb 21, 2006 8:56 am
Short answer is no. There are no native 10-bit or 24-bit data types.
You can create structures and use the UNION command to encapsulate data. But you will need to keep things on 8-bit boundaries or end up with wasted space.
Furthermore the data operators (+, -, etc) and functions are designed to use the native data types. If you created your own 24-bit integer you will also need to create your own 24-bit operators and functions.
The CCS compilers sometimes have problems with overly complex data structures so be prepaired to read LST and MAP files.
What part are you currently using? _________________ Rob Young
Ed_Banses
Posted: Fri Feb 24, 2006 6:44 am
Thanks for your answer.
I am using the PIC16F688 because the Ultra Low Power Wake Up feature.
I am going to take a look that you say, but I think that I am going to change the idea using the exotic data types.
Thanks a lot.
Eduardo
