Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
ICD_U40?? |
Posted: Wed Feb 08, 2006 5:16 am |
This is just a note;
I had a problem not with programming or even the code I was doing, for what ever reasion, the Micro was not getting programmed correctly.
I found that My PC had glitched internaly, Every was working OK, even the ICD_U40 was operating correctly with programming, just not able to program the micro corectly, (reboot the PC and every thing is now OK)
I was almost going to post this as a posible fault/bug?? a little bit of fault finding and all OK
Andrew _________________ What has been learnt if you make the same mistake?  |
Storic
Posted: Wed Feb 08, 2006 4:26 pm |
It happened again and I found that it is related to the WDT, switch it off, works OK, switch it on again (Fault), it appears that the WDT is resetting to soon, I have the WDT set to 1:128 (2304ms) I am using timer 0 to reset the WDT and pole a CPU led at 1/2 sec intervals
Code: | /***********************************************************
* Timer 0 (RTCC) output, CPU led, Reset WDT *
#int_RTCC
RTCC_isr()
CPUled++; // Increment value of cnt on every interrupt
if (CPUled == 240) {
output_toggle(CPU_led);
CPUled = 0;
restart_wdt();
Code: | void Inilize()
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16|RTCC_8_bit);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RTCC);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
Code: | #FUSES WDT //Watch Dog Timer
This only happens twice to 2 x boards. After doing some code manipulation, I got it to work OK, however when I put the original Code in that had this problem, It all works OK unable to refault. the micro is the 18F1320 and had been erased prior.
Should i have restart_wdt(); in the main program or is it OK where it is.
ANdrew _________________ What has been learnt if you make the same mistake?  |
Don't use restart_wdt() in a timer int |
Posted: Fri Feb 10, 2006 7:58 am |
Sounds to me like a really bad idea to restart the WDT in a timer interrupt. One of the reasons for having a WDT is to come back if you get stuck in some bad code somewhere in your application.
If you restart the WDT in a timer intrerrupt, I se no reason at all to have WDT enabled.
// Magnus |
