		| Author | Message |
		| sonicdeejay
				| Working LCD.c driver for Samsung based chip |
				|  Posted: Thu Feb 09, 2006 11:13 am |   |
				| I am using PIC18F2525 with a 2x16 matric LCD based on S6A0069 and works well so far...(thx to PCM programmer for his helps)
 This is my lcdmod.c
  	  | Code: |  	  | struct lcd_pin_map {                 // This structure is overlayed
 BOOLEAN enable;           // on to an I/O port to gain
 BOOLEAN rs;               // access to the LCD pins.
 BOOLEAN rw;               // The bits are allocated from
 BOOLEAN unused;           // low order up.  ENABLE will
 int     data : 4;         // be pin B0.
 } lcd;
 #if defined(__PCH__)
 #if defined use_portb_lcd
 #byte lcd = 0xF81                   // This puts the entire structure
 #else
 #byte lcd = 0xF83                   // This puts the entire structure
 #else
 #byte lcd = 6                  // on to port B (at address 6)
 #else
 #byte lcd = 8                 // on to port D (at address 8)
 #define set_tris_lcd(x) set_tris_b(x)
 #else
 #define set_tris_lcd(x) set_tris_d(x)
 #define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
 #define lcd_line_two 0x40    // LCD RAM address for the second line
 BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
 // These bytes need to be sent to the LCD
 // to start it up.
 // The following are used for setting
 // the I/O port direction register.
 struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
 struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
 BYTE lcd_read_byte() {
 BYTE low,high;
 set_tris_lcd(LCD_READ);
 lcd.rw = 1;
 delay_cycles(1);
 lcd.enable = 1;
 delay_cycles(1);
 high = lcd.data;
 lcd.enable = 0;
 delay_cycles(1);
 lcd.enable = 1;
 delay_us(1);
 low = lcd.data;
 lcd.enable = 0;
 set_tris_lcd(LCD_WRITE);
 return( (high<<4) | low);
 //Modified code to fit S6A0069 chip based LCD
 void lcd_send_nibble( BYTE n ) {
 lcd.data = n;
 delay_cycles(1);
 lcd.enable = 1;
 delay_us(2);
 lcd.enable = 0;
 //Orignal LCD format
 /*void lcd_send_nibble( BYTE n ) {
 lcd.data = n;
 delay_cycles(1);
 lcd.enable = 1;
 delay_us(2);
 lcd.enable = 0;
 void lcd_send_byte( BYTE address, BYTE n ) {
 lcd.rs = 0;
 while ( bit_test(lcd_read_byte(),7) ) ;
 lcd.rs = address;
 delay_cycles(1);
 lcd.rw = 0;
 delay_cycles(1);
 lcd.enable = 0;
 lcd_send_nibble(n >> 4);
 lcd_send_nibble(n & 0xf);
 void lcd_init() {
 lcd.rs = 0;
 lcd.rw = 0;
 lcd.enable = 0;
 delay_ms(30);
 lcd_send_nibble(0x02);
 delay_us(1);
 delay_us(1);
 lcd_send_nibble(0x0C);
 delay_us(45);
 lcd_send_nibble(0x00);
 delay_us(1);
 lcd_send_nibble(0x0F);
 delay_us(45);
 delay_us(1);
 lcd_send_nibble(0x01);
 delay_ms(2);
 delay_us(1);
 lcd_send_nibble(0x06);
 delay_ms(2);
 void lcd_init() {
 BYTE i;
 lcd.rs = 0;
 lcd.rw = 0;
 lcd.enable = 0;
 delay_ms(15);
 for(i=1;i<=3;++i) {
 lcd_send_nibble(3);
 delay_ms(5);
 lcd_send_nibble(2);
 for(i=0;i<=3;++i)
 lcd_send_byte(0,LCD_INIT_STRING[i]);
 void lcd_gotoxy( BYTE x, BYTE y) {
 BYTE address;
 if(y!=1)
 address=lcd_line_two;
 address=0;
 address+=x-1;
 lcd_send_byte(0,0x80|address);
 void lcd_putc( char c) {
 switch (c) {
 case '\f'   : lcd_send_byte(0,1);
 delay_ms(2);
 case '\n'   : lcd_gotoxy(1,2);        break;
 case '\b'   : lcd_send_byte(0,0x10);  break;
 default     : lcd_send_byte(1,c);     break;
		| sonicdeejay
				|  Posted: Mon Feb 20, 2006 7:19 pm |   |
				| In my main program..
  	  | Code: |  	  | #include <18F2525.h> // Call for PIC18F2525 Driver #device ICD=TRUE
 #device ADC=10 // Use 10bits ADC
 #use delay(clock=16000000) // 16Mhz Crystal is Used
 #use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)  // RS232 Configuration for COM Port Communication
 #define use_portb_lcd TRUE // Using Port B for LCD Display
 #include <lcdmod.c>  // This is Where I call for lcdmod.c
 #byte PORTB = 0xf81
 #byte PORTC = 0xf82
 #include <stdlib.h>
 #include <math.h>
		| sonicdeejay
				|  Posted: Sun Feb 26, 2006 6:29 am |   |
				| My physical connection is ...
  	  | Code: |  	  | LCD  -   PIC18F2525
 VSS   -   GND
 VDD   -   5V
 V0    -    O/P from variable ressitor (20KOhm)
 R/S   -  PORT_B1
 R/W   -  PORT_B2
 E     -  PORT_B0
 DB0   -   NC (not connected)
 DB1   -   NC (not connected)
 DB2   -   NC (not connected)
 DB3   -   NC (not connected)
 DB4   -  PORT_B4
 DB5   -  PORT_B5
 DB6   -  PORT_B6
 DB7   -  PORT_B7
 | You cannot post new topics in this forum You cannot reply to topics in this forum
