Saratoga
Problem with ds1302 Accuracy |
Posted: Tue Feb 07, 2006 1:51 am |
I have a problem with the precision of DS1302. In a day one goes ahead 5 seconds that him can happen?.The assembly is correct.
Thanks. _________________ To Pic Or No To Pic |
asmallri
Posted: Tue Feb 07, 2006 3:33 am |
Check you have used the correct crystal. The DS1302 and 1307 include internal capacitors for 12.5pF loading of the crystal. If you use the wrong crystal the frequency will be wrong. Another common mistake is to add external capacitors not realising they are already built in. _________________ Regards, Andrew
asmallri
Saratoga
Tks ..every its OK |
Posted: Wed Feb 08, 2006 4:19 am |
I do not have put capacitors.The cristal it is 32.768 Hz.
I have followed the considerations of this official page.
But no works correctly. 4 ,5 second bad in one day. _________________ To Pic Or No To Pic |
Saratoga
ljbeng
Posted: Wed Feb 08, 2006 8:20 am |
I had this problem until I used the correct crystal. It has to have a 6pF load capacitance. The crystal I used at first had 12pF and it would be off a few seconds a day. Now with the correct crystal, it works like a clock. Look at Digikey PN:300-8301-ND |
treitmey
Saratoga
OOOOOOKKKKKKK |
Posted: Thu Feb 09, 2006 1:28 am |
Working.
Thanks to everybody _________________ To Pic Or No To Pic |
