Problem with the ICD flag
berberis
PostPosted: Tue Feb 07, 2006 9:53 am     Reply with quote
I wrote the test program:
#include "18f6622.h"
#device *=16
#fuses PROTECT=15
#fuses WRT=15
#fuses EBTR=15
main()
When compiled this gave the listing:
CCS PCH C Compiler, Version 3.235, 27782               07-Feb-06 15:24
               Filename: C:\ccstest\main.LST
               ROM used: 26 bytes (0%)
                         Largest free fragment is 65510
               RAM used: 5 (0%) at main() level
                         5 (0%) worst case
               Stack:    0 locations
0000:  GOTO   0004
....................  #include "18f6622.h"
....................  //////// Standard Header file for the PIC18F6622 device ////////////////
.................... #device PIC18F6622
.................... #list
.................... #device *=16....................
.................... #fuses PROTECT=15
.................... #fuses WRT=15
.................... #fuses EBTR=15
.................... main()
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  MOVF   FC1,W
000E:  ANDLW  C0
0010:  IORLW  0F
0012:  MOVWF  FC1
0014:  MOVLW  07
0016:  MOVWF  FB4
0018:  SLEEP
Configuration Fuses:
   Word  1: 0F00   NOIESO NOFCMEN RESERVED
   Word  2: 1F1F   BROWNOUT WDT BORV25 NOPUT WDT32768
   Word  3: 81F3   CCP2C1 NOLPT1OSC MCLR RESERVED
   Word  4: 0085   STVREN NODEBUG LVP NOXINST BBSIZ1K RESERVED
   Word  5: C00F   NOCPD NOCPB
   Word  6: E00F   NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTRB
Which is what I expected, I changed the #device line to
#device *=16  ICD=TRUE
This changed the Configuration Fuses section to
   Word  2: 1E19   NOBROWNOUT NOWDT BORV25 NOPUT WDT32768
   Word  4: 0000   NOSTVREN DEBUG NOLVP NOXINST BBSIZ1K RESERVED
   Word  5: C0FF   NOPROTECT NOCPD NOCPB
   Word  6: E0FF   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 40FF   NOEBTRB NOEBTR
This causes problems when I try to download the code to an ICD-U40 as in the 6622 the last 3 configuration words have only 4 bits in lower byte so the download fails as the actual configuration fuses dont match the fuses generated by the compiler.
Any ideas?
