How can i make here an subroutine to reduce code size?
The Puma
PostPosted: Mon Feb 27, 2006 7:35 am     Reply with quote
   while(TRUE) {
      k=kbd_getc();
      switch(k) {
         case '1' :   if(toggle1)
                        output_low(RELAIS_K1);
                        output_high(RELAIS_K1);
                        toggle1 =! toggle1;
         case '2' :   if(toggle2)
                        output_low(RELAIS_K2);
                        output_high(RELAIS_K2);
                        toggle2 =! toggle2;
         case '3' :   if(toggle3)
                        output_low(RELAIS_K3);
                        output_high(RELAIS_K3);
                        toggle3 =! toggle3;
         case '4' :   if(toggle4)
                        output_low(RELAIS_K4);
                        output_high(RELAIS_K4);
                        toggle4 =! toggle4;
Alex N
PostPosted: Mon Feb 27, 2006 7:48 am     Reply with quote
Try to use
case 'x':
    output_bit(RELAIS_Kx,!input(RELAIS_Kx));
where 1, 2, 3 and 4 should be instead of x.
The Puma
PostPosted: Mon Feb 27, 2006 8:04 am     Reply with quote
This did not toggle the output pin
If i press the 1 key the output goes low, after i press the 1 key it will be low
It must go to high state
Alex N
PostPosted: Mon Feb 27, 2006 8:17 am     Reply with quote
[spam], if you press the 1 key and RELAIS_K1 is low, !input(RELAIS_K1) is high, which is placed to RELAIS_K1. Pay attention to !input.
rwyoung
PostPosted: Mon Feb 27, 2006 8:21 am     Reply with quote
Check to see if your compiler supports the output_toggle() function.
output_toggle(pin) where pin = PORT_A3 pin names
If not, XOR (~), the #BYTE and #BIT directives are your friends.
#byte LATCHA = 0xF89 //18F4520, your mileage may vary
#bit RELAY_K3 = LATCHA.1
RELAY_K3 = 1; // on
RELAY_K3 = 0; // off
RELAY_K3 ~= 1; // toggle
Rob Young
The Puma
PostPosted: Mon Feb 27, 2006 8:22 am     Reply with quote
This works
output_toggle(RELAIS_K1);
Thx for help
Alex N
PostPosted: Mon Feb 27, 2006 8:32 am     Reply with quote
Rwyoung, thank you for the useful information. It turned out, that my compiler (as opposed to the help index) also supports output_toggle function.
