Problem with ds1302 Accuracy
Saratoga
PostPosted: Tue Feb 07, 2006 1:51 am     Reply with quote
I have a problem with the precision of DS1302. In a day one goes ahead 5 seconds that him can happen?.The assembly is correct.
Thanks.
To Pic Or No To Pic
asmallri
PostPosted: Tue Feb 07, 2006 3:33 am     Reply with quote
Check you have used the correct crystal. The DS1302 and 1307 include internal capacitors for 12.5pF loading of the crystal. If you use the wrong crystal the frequency will be wrong. Another common mistake is to add external capacitors not realising they are already built in.
Regards, Andrew
asmallri
Regards, Andrew
Saratoga
Tks ..every its OK
PostPosted: Wed Feb 08, 2006 4:19 am     Reply with quote
I do not have put capacitors.The cristal it is 32.768 Hz.
I have followed the considerations of this official page.
But no works correctly. 4 ,5 second bad in one day.
To Pic Or No To Pic
Saratoga
The maxim page are
PostPosted: Wed Feb 08, 2006 4:20 am     Reply with quote
Sorry ..the web..
http://pdfserv.maxim-ic.com/en/an/app504.pdf
To Pic Or No To Pic
ljbeng
PostPosted: Wed Feb 08, 2006 8:20 am     Reply with quote
I had this problem until I used the correct crystal. It has to have a 6pF load capacitance. The crystal I used at first had 12pF and it would be off a few seconds a day. Now with the correct crystal, it works like a clock. Smile Look at Digikey PN:300-8301-ND
treitmey
PostPosted: Wed Feb 08, 2006 9:30 am     Reply with quote
I seem to remember 12.5pF but that must be a different part
according to spec sheet
page 4 x1,x2
http://pdfserv.maxim-ic.com/en/ds/DS1302.pdf
It should be 6pF loaded crystal.
Saratoga
OOOOOOKKKKKKK
PostPosted: Thu Feb 09, 2006 1:28 am     Reply with quote
Working.
Smile Smile Smile Smile
Thanks to everybody
To Pic Or No To Pic
