a very basic code not working? 16F870
digitalfreak
PostPosted: Wed Feb 08, 2006 11:58 am     Reply with quote
I have used (Mplab, picstartplus, CCS c compiler) a while ago, now kind of of lost touch completely...please help what am I doing wrong?
#include <16f870.h>
#device adc=8
#use delay(clock= 4000000, restart_wdt)
#fuses NOWDT, XT, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT
#include <math.h>
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
void main () {
  set_tris_a(0b00111110);
  set_tris_b(0b11111100);
  set_tris_c(0b00000000);
  setup_adc_ports(NO_ANALOGS);
  output_low(PIN_B1);
  while (TRUE) {
    output_high(PIN_B1);
    delay_ms(10);
just to be sure
pin 1 - pulled high to vdd (5V) using 5.1K rresistor
8 and 19 - ground
9 and 10 - 4MHz crystal and 33pF caps as shown in data sheet
20 vdd(5V)
I couldnot see HIGH (5V) on PIN_B1 what the heck....
I have programmed before and made few working circuits, this is killing me...
what could go wrong?
thx
sonicdeejay
PostPosted: Sat Feb 11, 2006 12:54 pm     Reply with quote
trying taking out...
and run it....??
Measure it again,,,
I ain't no expert..just a suggestion... Very Happy
PostPosted: Sat Feb 11, 2006 4:20 pm     Reply with quote
The program as written should work.
He has fast_io selected, so needs the TRIS statements. B1, is correctly set as an output.
Realistically, at this point one would be looking for something faulty. A crystal not oscillating. A chip that is damaged. An IC socket that is not actually making good contact. A supply that is not quite good enough, triggering a brownout. Inadequate decoupling, causing the chip to reset.
What compiler version?. if old, there might be a problem here.
